CA Hydraulic Pump Prime Loss
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Pump Prime Loss
    Posted: Yesterday at 3:55pm
I know that the system has thicker oil than specified (30wt vs 20wt), because the NAPA guy didn't give me what I asked for when I backed the truck up to the dock.  It is just a little slow to prime and sometimes loses prime when in hold or down (it's a 1952 and doesn't have the inlet check ball that some possibly later ones had).  It also has a leak around the plug at the top rear of the pump.  I think either the rebuilder didn't include the crush washer or it needs a new one.  I'll try to fix that next trip.  Could a leak at that plug contribute to loss of prime (it doesn't squirt but is a fairly constant dribble under pressure)?  I've mostly resolved the cylinder leaks.
After the first of the year, I'll probably change out all the fluids and correct the viscosity issue.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:23pm
any air inlet leakage can cause a loss of prime over time.. Make sure the oil level is UP TO MAX also... I have a B that i run an inch over the level mark to keep the pump primed when i travel DOWN steep hills........ i added a 45 degree elbow to the fill port and  fill to that top instead of the threads in the trans case..
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:47pm
I topped it off last trip and it improved slightly.  It was only about a 1/2 cup low though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 0 hours 60 minutes ago at 3:09pm
I see that the intake check valve was added at SN17441 which was also in 1952.  I guess they recognized an issue that needed correction.  I was wondering how it was installed but it looks like they added an access port/plug on the outside as well.
Edited by dfwallis - 48 minutes ago at 3:21pm
