CA First Use - Lost Oil Pump Prime
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA First Use - Lost Oil Pump Prime
    Posted: 19 May 2025 at 3:11am
It's held prime for a year then lost it overnight following first use. Found a disturbing flake of probably old gasket material in the line feeding the filter. I assume particles caused the check ball to stick...is that plausible? It primed easily.   I guess I'll do an oil change.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
