CA erratic spark
 Post Reply Post Reply Page  <1 3456>
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 3:23pm
when you choke it, it will REV UP right ? ... Not something like a timing issue way advanced at high RPM ?  .... Sure it is CARB related ?
What if the Intake manifold or gasket had a leak and was sucking air ? ..... Restricting the air ( choke) makes the engine SUCK harder and more monifold vacuum  ?  Les thought your vacuum was on the low side ?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 3:45pm
Replaced the main idle jet in the tsx. Not significantly different running. It was really difficult to get out. The easy outs are too short for brass. Got most out then retapped the hole. Not going to try the main jet. Too hard to get to and these easy outs won't reach. Misses are back but runs all rpms fineish. So, probably going to send the tsx out for professional rebuild. I've replaced everything in it but the main jet. I also tweaked the float to shut off slightly sooner. No change.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 3:48pm
I think the low vacuum reading was due to cheap uncalibrated meter. But I'll verify when my brother brings a higher quality one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2025 at 3:52pm
I tried adjusting timing with the Zenith...could not resolve the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 3:14pm
Brother brought a better quality vac meter. Engine reads 22 in hg, steady. Agrees with my cheap farmer calibrated meter...
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 6:48pm
Excellent! Smile
That means you do not have sticky valves and your rings are sealing properly.
Once you get the correct carburetor on there with the proper jetting your troubles should be over.
Hang in there Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 8:07pm
Place i sent the carburetor to has been repairing all types of carbs for 80 years...and can actually test them...that part wasn't clear at nearly all the other places I looked at...fingers crossed...
Edited by dfwallis - 24 Jul 2025 at 8:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 11:38am
In steps, I've increased the jet all the way .082...I no longer have to use the choke to get full throttle range, but any time the governor revs it it still dies unless I recover it by choking. And thats only with the adjusting screw all the way out. Screw it in, reduces the throttle running range.
Seems like a ridiculously large jet for a tiny engine...I may as well see where it goes with further increases. But then again, only a little larger than the tsx 486 new jet size of .780.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 12:21pm
.089, best behavior so far...starting to have some adjusting screw effect. Super snappy governor as long as it doesn't rev too much...seems far fetched...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 1:45pm
Hmmm, tsx 486 carb info says the economizer jet is .0775...the main is .0990...#39 drill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 2:11pm
So, are you now dealing with the TSX unit and was it professionally rebuilt and tested?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 2:41pm
No, tweaking the budget chinese knockoff zenith...I went all out and bored the main jet out to .0990...it now runs almost normally. It does have a slight wavering behavior at max throttle, but it might actually be usable now. Unfortunately, there's not much meat left on the jet for more boring. But I also now have some control with the adjusting screw. The tsx probably won't be finished before this trip ends on Saturday. Next trip probably late Aug. This carb obviously should not have been marketed as a 486 replacement...should have been 12522...guessing somebody cut and pasted wrong...hey but I got it for less than 1/3 of a zenith...what's a little frustration and anger...
Edited by dfwallis - 30 Jul 2025 at 2:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 3:44pm
Had it apart waiting for a delayed ups shipment and just got a chance to take it for a spin. My gosh, it ran great! 99.44% miss free. I may be afraid to reinstall the tsx when it comes back. It should be finished sometime next week he said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 3:50pm
It seems odd that you would have to bore the main jet THAT FAR OVERSIZE... but you had the symptoms of "lack of gas".... so yes, what ever works is a great solution !!
One step at a time till you get there......... I think your there !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2025 at 3:53pm
i notice that the REPLACEMENT carb was bored to .099 ... and the ORIGINAL TSC had a .099 inch  main jet......... so MAYBE they just put the WRONG MAIN into the knock off carb !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 9:03am
...Question...the Zenith main jet is not the same size all the way through...the very tip is much smaller. Either it is stepped or they didn't bore all the way through...docs online seems to suggest Zenith does not use stepped or tapered jets ??...
Perhaps the whistle blew for quitting time before the drill got all the way through? Tongue
No, tweaking the budget chinese knockoff zenith...I went all out and bored the main jet out to .0990...it now runs almost normally...
Since the vacuum signal will be the same for both types of carburetor, and the fuel level in the float bowl is specified to be the same height (according to my manuals) it makes sense that the main jet diameters should be pretty near the same size for each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2025 at 2:03pm
... bored the main jet out to .0990....
...Unfortunately, there's not much meat left on the jet for more boring...
Since it appears that you are very close to size on the main jet I would suggest polishing rather than drilling to final size.
Dunk a q-tip in some mild polishing compound (maybe cheap toothpaste) and chuck it in a drill. You may need to peel some cotton off of the swab, but it needs to fit pretty snug inside. Buzz it around for 30 seconds or so, then look inside. Repeat until you get bored.
Post Options Post Options   Thanks (1) Thanks(1)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 11:39am
Contacted the carb rebuilder today.  He has had considerable difficulty getting some of the mangled components out but now has everything apart.  Hopes to complete by next week.  He's trying to locate the specific replacement parts rather than a full kit since I already installed the full kit minus those mangled jets I couldn't easily remove.  If he can't find them, he'll go for the full kit and use what he needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2025 at 5:39pm
The carburetor rebuild is complete and it's on its way back home just in time for my next trip.  I sure hope this is finally put to bed.   He indicated that he found what he thinks is a  part from a type C/adjustable-load-jet carburetor in behind a mangled jet (those universal kits contain a lot of extra parts not applicable to a type a).  And of course it was also dirty/rusty in those passages.  I'm sure its been that way for decades, even before it was parked.  Confused
Edited by dfwallis - 21 Aug 2025 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 7:04pm
Inspected the rebuilt carburetor. My gosh, he does excellent work. It looks factory new, shiny even. I hope it works as good as it looks. I'll find out tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 10:42am
Well...bad news. It runs just as bad as before... couldn't tell even a hint of difference in behavior with the tsx486...I am more than frustrated what the heck could be wrong with this carb???
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 12:01pm
Same symptoms with two different carbs says the problem isn’t with the carb.
This has been a long post so I don’t remember if you sprayed carb cleaner around the manifold to check for air leaks or not, but the problem doesn’t seem to be the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 12:09pm
No, it runs pretty good with the Zenith after I modified it...but the Zenith doesn't fit well. It is almost completely miss free with the Zenith...I really want the correct carb, not a kludge crappy one. The Zenith still doesn't run well at higher rpm. It wavers up and down...but no misfires...the tsx misfires at all rpms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 2:40pm
After dismantling the "rebuilt" TSX 486, I've found incorrect jet size/placement, so I've shipped the carburetor to TX and will give it another look.  I've found better service documentation now which should make it easier and more thorough.  I also see what appears to be microcracks in the bottom of the float bowl, but haven't confirmed it yet.  I found that the "economizer" jet (the last non-removable/mangled one) was previously installed at the wrong location (according to it's size of 0.0775"), according to an AGCO drawing.  A smaller jet is now installed at the economizer location.  I'm not sure that matters at idle though.  I think it is more effective at high throttle settings.  There's no economizer jet (0.0775) at any jet position now.  Luckily, I have a brand new one and will correct that.
The rebuilder had complained to me about not finding adequate documentation for the fixed jet TSX carbs (only the type C).  But I don't see the above as being substantially different in the type A.  He did mis-identify the carburetor on the invoice as a Zenith, but when we spoke by phone he seemed aware it was a Marvel.  Confused
I made additional mods to the Zenith 12566 for fitment.  At least the throttle plate is not hitting the sides and getting stuck.  It generally runs good as long as the governor does not kick in.  While mowing, I turned the front wheel a little too sharp and it died instantly.  Attempting to back it into the barn, up on a 4 inch high pad lip, it kept dying.  Liked to never got it back in there.  I've since learned to idle it down quite a bit instead of speeding it up. Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2025 at 7:22pm
Well, my irreplaceable TSX486 is lost somewhere in the USPS.  I shipped 2 packages priority.  One arrived in 3 days, the other (the important one) has been in transit for 8 days.   AngryConfusedCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2025 at 6:14pm
The carburetor is at least in the right city now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 12:49pm
After being told there was none available, a rebuilt tsx670 showed up unexpectedly...whoever said it was compatible with a ca (1952) was very wrong...anything that requires extensive mods is not compatible...however, I was able to use old 486 parts to mod it to work. Since the bolt pattern is wider, I also had to widen the manifold outer sides...the 486 should still mount with proper alignment. The 670 throttle rod sticks out a few inches and prevented mounting. I modded the 486 rod to work with the larger throttle plate which had to be trimmed just slightly so it would close enough to get an idle rpm. I had to swap the choke arm for the 486 arm to match the rod clamp hole size. I made the throttle control arm adjustable so I could get the angle to agree with the 486 settings. Result is it now idles misfire free like the Zenith. Better than the 486, but it still misses some at higher rpm. This one has a load adjustment at the top front. I'll continue to try adjusting to see if i can get it right. Is the 670 slightly higher cfm than the 486? I need to do more jet and venturi comparisons. At least it is fully usable again.
Edited by dfwallis - 13 Sep 2025 at 1:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 1:18pm
670 venturi is 3/4 vs 5/8 for the 486.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2025 at 7:09pm
That's a pretty significant difference in area Shocked 0.442 square inches vs 0.307 square inches if I did the math right.
You may be able to tune it but the vacuum signal will be a lot different at the jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2025 at 8:35pm
I recently dug through my boneyard and found the original manifold complete with the Zenith carburetor from the old Model C that I call Mr. Cato's tractor. The carburetor is rusted quite badly but I was able to remove the plug covering the main jet and was able to do a crude measurement of the orifice. A 0.055" drill bit entered freely, and a 0.059" would not enter at all. I would guess the true size close to 0.057".
I have yet to decipher the numbers on the carburetor tag due to the heavy corrosion, but judging by the yellow paint it is no doubt the carburetor that was on the tractor when I saw it running back in 1964; the last time I saw it run was in the late 1960's.
The point being that I find it peculiar that a carburetor for a similar engine would require such a huge increase in jet size. Confused
