CA Aftermarket Muffler Mounting Hole Absent
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Aftermarket Muffler Mounting Hole Absent
    Posted: 14 May 2024 at 8:38am
The new manifold doesn't have the bottom hole drilled.  Should I drill and tap one or is one bolt enough?  It seems like it should be fine as long as the muffler material is intact (stainless steel muffler).
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2024 at 9:50am
I think most of my "B" tractors were setup with only 1 bolt..  Two would make it more stable, but the one seems to work as long as you dont bump it too hard.
Some manufactures put the extra hole in the manifold for the CA muffler... same manifold fits the B-C which only has one hole.
Edited by steve(ill) - 14 May 2024 at 9:56am
