BEST PULLING TRACTOR FOR THE BUCK |
Page <123 |
wrightk20
Posted: 12 Mar 2013 at 1:44am |
dear moderator, please get rid of mlpankey!
WCCLASON
Joined: 01 Jan 2010 Location: Viroqua Wi Points: 106 |
Posted: 12 Mar 2013 at 3:17pm |
I would vote for Unstyled WC. I took both motors and built them up. Both are running 65 to 75 hp. I like the diffrent look of them. Not alot of people have them around my area. I have two. one is going on four years same motor, and the other one i am in the middle of working on the motor. Want to have one to keep playing with....and alot going to have it all painted up for this summers pulling season.......Hope things change on here soon becuase i am to the point of not asking any opinions because you dont know whats fact or BS.
I have a few i talk to and thats it anymore.
patrickmull
Posted: 12 Mar 2013 at 5:09pm |
wcclason what kind of hubs do you have on the front
WCCLASON
Posted: 12 Mar 2013 at 6:08pm |
Some unstyled WC had a 6 bolt front end. That's what I have. Not sure why though...
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 12 Mar 2013 at 6:26pm |
They used them in 1937 and then went back to 5 hole after that.
WCCLASON
Posted: 12 Mar 2013 at 8:28pm |
The tractor I have is a 38..serial number checks out and the tractor was un change. Had cultivators on it for its whole life.Stayed on the same farm since new. Was an all pressed steel wheel tractor I guess u could say from factory....kinda rare for 38?
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 12 Mar 2013 at 8:39pm |
WCCLASON
Thanks(1)
Posted: 12 Mar 2013 at 9:36pm |
And back to the topic of the conversation....You can have a great power to weight ratio with a unstyled WC. Not much can touch one in a 3500 lb class.
And another note....Has anyone ever thought of the amount of driveline power loss in a WC compaired to the WD WD45? Just a thought.....WC has Bell housing then a pretty simple trans. Then a tourqe tub then right into the rear axle housing. On a WD you also have the cam system that runs the hydro pump . Just seems like more rotating mass for you to lose HP in the drive line? Im sure its not much but maybe i am over thinking it.
THE-MAN
Joined: 11 Mar 2013 Location: By the lake Points: 156 |
Posted: 12 Mar 2013 at 9:49pm |
Dont forget that drop axles are a very efficient transfer of power. Id stick it out with a WC, if you can turn the high gear ratio. Simple and Cheap
Posted: 13 Mar 2013 at 6:58am |
With the hydraulic pump and PTO gears and hand clutch removed, a WD or WD45 efficiency is the same as a WC. In fact an old WD transmission is the same as a WC, only located farther back in the chassis. The outboard (dropped) final drives have no advantage over any other bull gear design for power transfer.
THE-MAN
Posted: 13 Mar 2013 at 7:24am |
I was under the impression that it was slightly more efficient than other designs. I certainly like the hitch options because ofvthe added height.
WCCLASON
Posted: 13 Mar 2013 at 7:48am |
Great input guys. this is why i read the fourm! I kinda forgot you could strip all that crap out of the wd trans. That would help alot. All i know is radiator work is esxpensive for them! i can just go to the internet and buy a new radiator assembly. |
WCCLASON
Posted: 13 Mar 2013 at 7:50am |
Sorry...to early yet.... Forum**
cotncrzy
Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
Posted: 13 Mar 2013 at 8:15am |
If I could of found one I would of had a WC. They are rare birds around here. My great uncle had one, unstyled, I think a '37. I finally got it after he passed away. I bought it from my great aunt for scrap price, without really looking at it. To make this post short and to the point, Engine ,trans, was full of water and had a busted trans. housing. All the bearings were siezed in the rear which was also full of water. I just didn't think it was worth the trouble, salvage yard had very limited suppy of parts, looked like a money pit, I lost $50 on it, end of story. I wish I had it to do over.....
They are almost impossible to beat in the 3500# class, but it has been done! Stripped down I bet one weighs less than 3000#, that allows for moveable weight to balance the tractor. I run a WD, stripped, it weighs 3300# my son drives it in the 3500, most pulls allow 100# tolorance on scales so we can weigh 3600# We can run 65 to 100 # depending on how the scales weigh where you are at.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
michaelwis
Posted: 13 Mar 2013 at 8:24pm |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
WCCLASON
Posted: 13 Mar 2013 at 9:37pm |
i was just looking at the pictures on that site and a few of them are pulls i go to...! maybe il see you around! what do you pull.. Michael?
michaelwis
Posted: 13 Mar 2013 at 10:50pm |
Used to do ok with my 7040 being i,m an antique , thought i might as well pull with one
Isqujab
Joined: 20 Jul 2024 Location: Martinsville in Points: 3 |
Posted: 14 Mar 2025 at 5:35pm |
How much stroke can you physically get in a226 block
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 945 |
Posted: 15 Mar 2025 at 8:42am |
I’m not sure what exactly the off track uses you have in mind. But my nomination is also WC. You don’t have to go crazy to build a competitive one. One our most successful pulling tractors for over 20 years involves a 240 inch WD45 based engine in a styled WC with high crop gears. I’ve run out of places to put all the trophies won piloting this tractor in 3,500, 4,000, & 4,500 pound classes. A successful pulling tractor is much more than just an expensive/exotic engine build. The guy who knows how to read a track, set up his tractor, and drive his tractor will OFTEN beat the guy on his imaginary poorly running 400+ inch tractor. I’m not sure why, but I think that a WC based puller just has some inherent advantages over a WD/WD45 or D17 based tractor pulling in the same weight classes. Our tractor still makes a reliable tractor drive and parade tractor, and it could still be used for many farm tasks that don’t require a tractor with hydraulics or mounted implements. This is just my opinion, based on over 25 years of experience! Kip
Honey B
Joined: 28 Oct 2012 Location: Jasonville IN Points: 49 |
Posted: 15 Mar 2025 at 2:54pm |
I live in southwest IN. I've pulled at Emenice, Hazelwood and south. Tracks sticky pack clay. Require a lot HP power if your pulling a 4 and 6 MPH. You just miss Hayden Gibson HOT WC it sold at auction in KY last week 18.4x38 tires and a lot of HP. What class are pulling?
Page <123 |
