Bar's Leaks Head gasket sealant |
Page <12 |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3405 |
Posted: 30 Mar 2025 at 12:39pm |
Checking for water in the engine oil today. It's been dripping out way before the oil does. Kept unscrewing drain plug until oil started pouring out
Glad I had a catch pan in place. Almost time for the annual oil change anyway. Thanks |
ACinSC
Posted: 03 Apr 2025 at 10:19am |
Loosened drain plug today without dumping all the engine oil. Saw only a few drops of oil, no water. Maybe I got lucky? I'll drain the water and add antifreeze soon. Thanks!!
Posted: 03 Apr 2025 at 5:46pm |
With warm weather on the horizon, I'd for sure be leaving the doctored up water in it until next fall.
Joined: 11 Sep 2009 Location: illinois Points: 93501 |
Posted: 03 Apr 2025 at 5:55pm |
Some of the BARS LEAK is compatable with antifreeze.. You might drain half and refill with antifreeze to get a 50- 50 mixture... Or maybe just put 2-3 spoons full of sealer in with the NEW ANTIFREEZE as a DOUBLE CHECK for future problems..
Depending on how you "DRAIN"... you might still have 2-3 quarts of water / sealer in the engine block.... That might be enough for "on going" maintenance of the system... ? Edited by steve(ill) - 03 Apr 2025 at 6:04pm |
ACinSC
Posted: 03 Apr 2025 at 7:17pm |
The stuff I used can't be mixed with antifreeze. I flushed the system several times before and after. I opened the radiator petcock and the one behind the carb.I'll pick up some antifreeze soon and keep an eye on it. Thanks!!
Edited by ACinSC - 03 Apr 2025 at 7:19pm |
ACinSC
Posted: 31 Mar 2026 at 7:10am |
Update. Yesterday I backed out the engine oil drain plug until a few drops of oil came out. No water/coolant! Seems the Bars Leak worked! Thanks guys for the help. Hard to believe it's been a year ago.
Luke R.
Posted: 31 Mar 2026 at 9:47am |
Mendtite best stuff ive found
ACinSC
Posted: 31 Mar 2026 at 10:14am |
Thanks Luke. Hope I never need any stop leak stuff again though.
Page <12 |
