B engine
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: B engine
    Posted: 51 minutes ago at 10:16am
How do you get the crank pulley off? Got the setscrew out. Tried a couple wood wedges. Wont budge. Doesn’t look like a 3 jaw puller will work. I don’t want to ruin it.
And what do you use to get the nut on the setscrew loose? I used a chisel, it wasn’t that tight.
'41 Allis B
'49 Farmall Cub
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 minutes ago at 10:56am
I got a large bearing separator from HF and used that as a puller. Worked good. You have to be careful not to damage the pulley.
