another wd hand clutch question
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: another wd hand clutch question
    Posted: 21 Aug 2026 at 9:29am
can the wd be changed to the wd45 three disc setup  if so i would start gethering parts so i can do both clutches on my wd  when i get the d17d done
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 9:37am
Parts were made to be interchanged between the two types.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 2:03pm
My question would be, why would anyone want to change one in 2026. Every WD is at least 73 years old. It's days of being the big chore tractor are long gone. If the 2-disc lasted this long, I would suspect it will last a lot longer than any of us will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 5:03pm
because if i have to change it bigger is better,              and i go pull it afew times a year up untill  the last few years it only sliped pulling now it slips plowing shims were all gone years ago
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 6:01am
I went through the hand-clutches on both my 45’s. Both ‘53 models, upgraded them to 3-disc. Found new and good used parts on E-bay back then. You might still be able to do that?
