Allis Sae 20W20 barel of oil.
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: Allis Sae 20W20 barel of oil.
    Posted: 17 hours 32 minutes ago at 10:24pm
I have a sealed 55gallon barrel of Sae 20W20 oil from Allis.  I no longer need this.  Any interest.  Thank you.  Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 41 minutes ago at 11:15pm
Hydraulic oil ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 8 minutes ago at 7:48am
Barrel is labeled SAE so I was thinking Motor Oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 3 minutes ago at 9:53am
Probably a gasoline engine type of oil, I'd imagine.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 36 minutes ago at 10:20am
Hydraulic oil is labeled SAE too
My mistake, hydraulic oil is aw or iso
Edited by john2189 - 5 hours 31 minutes ago at 10:25am
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 35 minutes ago at 12:21pm
I was thinking WD-45, D17, D19 as we used to have those tractors for light duty use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 2 minutes ago at 12:54pm
SAE is Society of AUTOMOTIVE ENGINEERS... which means the oil must be ENGINE COMPATABLE... 20W20... basiclly means its a straight 20wt engine oil.... You can use 2owt engine oil as HYDRAULIC oil in most of the older tractors... maybe pre 1960..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 57 minutes ago at 12:59pm
newer HYDRAULIC OILS are labeled "AW"  .. which means it has ANTI WEAR addatives in it specifically for  valves, pistons and pumps... normally with anti FOAM additives also..
