Allis Sae 20W20 barel of oil. |
twinson
Topic: Allis Sae 20W20 barel of oil.Posted: 04 Oct 2026 at 10:24pm |
I have a sealed 55gallon barrel of Sae 20W20 oil from Allis. I no longer need this. Any interest. Thank you. Jim
Posted: 04 Oct 2026 at 11:15pm |
Hydraulic oil ?????
twinson
Posted: 05 Oct 2026 at 7:48am |
Barrel is labeled SAE so I was thinking Motor Oil.
Posted: 05 Oct 2026 at 9:53am |
Probably a gasoline engine type of oil, I'd imagine.
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 512 |
Posted: 05 Oct 2026 at 10:20am |
Hydraulic oil is labeled SAE too
My mistake, hydraulic oil is aw or iso Edited by john2189 - 05 Oct 2026 at 10:25am |
'41 Allis B
'49 Farmall Cub |
twinson
Posted: 05 Oct 2026 at 12:21pm |
I was thinking WD-45, D17, D19 as we used to have those tractors for light duty use.
Joined: 11 Sep 2009 Location: illinois Points: 93506 |
Posted: 05 Oct 2026 at 12:54pm |
SAE is Society of AUTOMOTIVE ENGINEERS... which means the oil must be ENGINE COMPATABLE... 20W20... basiclly means its a straight 20wt engine oil.... You can use 2owt engine oil as HYDRAULIC oil in most of the older tractors... maybe pre 1960..
Posted: 05 Oct 2026 at 12:59pm |
newer HYDRAULIC OILS are labeled "AW" .. which means it has ANTI WEAR addatives in it specifically for valves, pistons and pumps... normally with anti FOAM additives also..
Posted: 05 Oct 2026 at 6:43pm |
Well, if it says ALLIS-CHALMERS on the barrel, it should be pre-1985 for age, which would make it 40 years old minimum. From about 1970 onward, the hydraulic oil was "Power Fluid 821", which was used in transmissions and hydraulic systems. In a D-19 owners manual, the hydraulic oil requirement was SAE 20-20W non-detergent of "ML" service classification. It's hard for me to believe there isn't anything else printed on the barrel to help figure out what type it is.
Les Kerf
Posted: 05 Oct 2026 at 7:20pm |
My late Father-in-law ran Pennzoil 20W20 motor oil in his vehicles and the WD Allis year 'round. I haven't seen it for sale in many years now.
Mikez
Posted: 06 Oct 2026 at 6:42am |
Can you post pictures
Posted: 06 Oct 2026 at 6:49am |
1. The Meaning Behind the Two Ratings
Historically, the SAE separated 20-weight oils into two distinct designations based on temperature testing:
2. Why it wasn't just called "20 wt" An oil could technically pass the high-temperature test to be called an "SAE 20" but fail the cold-temperature test because it contained too many natural waxes that solidify in the winter. Conversely, an oil could pass the cold-flow "20W" test but thin out too much at 100°C to meet the tight window required for a standard "SAE 20". When refining techniques advanced, manufacturers produced high-quality base oils that easily passed both the cold-weather cranking limits of a 20W and the hot operating limits of an SAE 20 without needing chemical viscosity index improvers. To prove to consumers that the oil was safe for year-round use (both winter starting and summer driving), they explicitly labeled it 20W-20 Edited by steve(ill) - 06 Oct 2026 at 6:50am |
