Allis drag disk
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: Allis drag disk
    Posted: 06 Oct 2023 at 12:40pm
I have an Allis chalmers drag disk , I was curious if any one would be able to identify it by model number ect . It has a couple bearings out on the gangs and I figured it may help trying to find parts
185 turbocharged w/ 500 loader , WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 1:19pm
Right there on the bearing housing is a part number to get you started.
juniorp53 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 2:08pm
#9 pull type   bearings are wood  made of  rock maple    most folks make there own    off the top of my head  inner dia is 2" and outside dia is 3 1/2"    soak in hot oil bath  before install then grease initially and after  every few hours of use
some guy out in Minnesota was advertising he had some NOS ones  talked to him on the phone  wicked nice ... said he would call back with some measurements  ...never did
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 3:22pm
Do you think oak would be any good to make bearings ?
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 3:36pm
    I think oak would be good/
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2023 at 4:30pm
I think hard maple is better than oak.  It is closer grained and less acidic than oak.  Lignum vitae (iron wood) is the preferred wood for water turbine and ship shaft bearings.  However, it needs to be kept wet even when in storage.  Hard maple was the second choice as it became harder to get Lignum vitae.
For disc bearings hard Maple would likely be better than oak.  It is closer grained and is less acidic than oak.  Maple is often soaked/boiled in hot oil or wax to add to its lubricity further into the wood.   There are several outfits making wood bearings using hard maple.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2023 at 7:42pm
Thanks for the info , does anyone know a good place to get the wood bearings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 5:54pm
talked to these folks few years back    explained to them over phone what i had and seemed like no problem for them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 7:49pm
I think I kept a nos for future measurements.
Edited by Mikez - 10 Oct 2023 at 8:01pm
