Allis drag disk
185turbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Topic: Allis drag disk
    Posted: 12 Sep 2021 at 9:28pm
I have a 8 ft drag disk and the bearings are out on the front left gang. Does anyone know where to get them or if they are available??
will try and a attach a picture
Thanks
185 turbocharged w/ 500 loader , WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2021 at 10:03pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 9:10am
The old Allis drag disks like that that I see have wood block bushings not bearing. You could make your own wood block or get some poly bars from McMastercar and made your own. They have some especially slippery ones designed to be used as bushings.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 9:24am
Call Gary Agrimson. I think he had some plastic bearings made.
763-566-3446
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 12:09pm
Pretty sure these are metal bearings with grease zerks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 3:37pm
Take another look. There's an Allis drag disk at Grandpa's. I think it's wood blocks with grease zerks. The balpak bearings used by Allis a little later weren't greaseable.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 6:41pm
How rare are they?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 185turbo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2021 at 10:12pm
These have a cast outer housing and there will is a metal inner race on the gang shaft I will try and get pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 9:34am
Take a look in the knowledgebase section. There is an article on rebuilding the balpak bearings. It has some pictures and you can see if they match what you have.
Are these drag disks rare? I know of several but I think generally these are getting scrapped by now. Neat old pieces but not very useful anymore.
