Allis Chalmers wd45 hand clutch
 Post Reply Post Reply Page  <1 456
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 3:07pm
I can make the gasket work
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 3:35pm
Is stop leak ok to use in the transmission clutch differential fluid and the hydraulic fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 3:59pm
NO.  Use oil resistant RTV lightly rubbed onto the paper gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 5:32pm
Will any trans hydraulic fluid work.
I usually get harvest king at theisens
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:00pm
You can use about anything and it will be fine. Remember, it came with an 80/90 gear oil, so if you go to a lighter viscosity, there may be more leaks. Takes 4 to 4 1/2 gallons total into the two fill plugs on the left side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:10pm
Ok so 80/90 is best.
What if I go heavier.
Also how many drain plugs are there I only did the hydraulic one and the one under the pto
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:21pm
If you did the hydraulic sump, that is another 6 quarts of hydraulic oil. Take out EVERY drain plug, which I think is FOUR.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 6:37pm
So 4 including the 2 I did already
Can I get 80/90 gear oil still
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 7:38pm
I'll try to get 80/90 but I might just get trans hydraulic fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 9:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2024 at 11:05pm
Only has to seal around the outside. I don't see what's different but it's too close for me to figure out. Pull the drain plugs and let it empty out. I think there's 2 under the trans/rear end. You can try to rinse it with diesel fuel. Put fresh trans-hydraulic fluid in all compartments and forget "stop leak". Everything except the engine can use one (same) fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 12:26am
The new gasket doesn't have the bottom hole.
So I can use the oil I showed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 8:17am
The link don't work but it says hyd and trans so I'm guessing yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 8:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 9:10am
I'll double check the gasket later today when I go to bill deppes
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 11:01am
Is there anything else I should know when I put the tractor back together other than to line up everything
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 2:31pm
You need to align everything so it slips back together. You may have to put the PTO in gear and turn it to get the shafts aligned.
DO NOT PULL IT BACK TOGETHER WITH BOLTS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 8:59pm
The tractor is back together and the hand clutch works
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 9:44pm
WOOHOO!!! SmileSmile
It would have taken me at least a week to do all of that! (I don't move quite as fast as I once did).
Good job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 10:19pm
Good to hear!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 6:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2024 at 11:43am
There are precious few 17 year olds nowadays that would tackle a task like this. Keep up the good work!
