Allis Chalmers wd45 hand clutch
 Post Reply Post Reply Page  <1234 6>
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:07am
From the hand clutch itself. That keeps the pressure plate contained which allows for a NEUTRAL/ disengaged position of the clutch plates/discs. That one is junk. I doubt that a new one can be had from AGCO. If you found a good used one you might be able to worm in into place in-chassis when the hand clutch fully engaged exposing the groove that wire fits into.
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:10am
What is it called so I can attempt to locate a new one
So if I replace it my hand clutch should work again
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:29am
YUP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:29am
Awesome
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:30am
I know that the hand clutch used to work because my grandpa and dad had used it 19 years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:37am
That is the snap ring that holds clutch together. It's bent . Should be a perfect circle. Your clutch cannot function properly . There was no "snap" in the clutch like that. You were asked about the "snap".
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 10:50am
it does make a loud snap when I push it forward
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 11:04am
I have a ac wd for parts at my grandmas house. I can't remember if it had a hand clutch, if it does could I take the snap ring form it to fix the wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 5:06pm
Would it be best to buy the new snap ring
Or would I be fine buying one from a tractor salvage yard
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 12:05am
A used one is fine. The WD should have the same ring on the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 12:08am
If the rest of the clutch is okay, replacing the ring should make good to go. I'm pretty sure you can get it back in place in the tractor. I think it has to be snapped in not released but I'm not sure.
Edited by SteveM C/IL - 02 May 2024 at 12:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 7:52am
I'll get a used one from the tractor salvage yard near me because the wd did not have a hand clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:04am
Never seen a WD without a hand clutch. You sure it's not a WC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:14am
It could be
I could have sworn that the sticker was wd
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:17am
After looking up a wc I do believe that it is a wc
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 8:19am
How would I take a snap ring out of a used tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 10:27am
so it is possible to install the new snap ring without removing the clutch from the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 11:45am
Pretty sure you can get it over shaft and work it in place
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 2:45pm
Just got one from my local tractor salvage yard for 5 dollars
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 4:36pm
I cant get the ring on without it bending out of shape
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 5:00pm
You have to get one end started and pry it over the edge as you work it around. It will distort some as you go but be fine once in place.its up to you to figure out how to pry and where to pry. It will be a frustrating learning experience but it's possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 5:10pm
I got the ring on the shaft but it was to bent out of shape to stay In place
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 10:29am
I'm going to try a different way to get the ring on
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 10:33am
If the ring is not too bad you can save it. Flatten it on vice or anvil with hammer. Compress it a bit to get to the size you want and try again. To get it in place use snap ring pliers unless you do not have space to do that.
Edited by Ed (Ont) - 03 May 2024 at 10:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 10:38am
what kind of snap ring pliers work on that kind of snap ring and size
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 10:41am
i did get it back to the right shape
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 11:04am
instead of trying to get the ring on by pushing it straight down i am going to try to carefully twist it open and push it on. is this a good idea. i can use all the ideas i can get before having to split the tractor as a last resort
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 11:18am
Flat blade snap ring pliers that OPENS wide enough would beat splitting the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 11:35am
I don't have any snap ring pliers like that
