Allis Chalmers 200 needs more power
Sparks farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparks farm Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 200 needs more power
    Posted: 24 Sep 2026 at 9:49am
I have a stock 200 that i would like to have 15-20 more HP to help pull a Chopper is there a turbo or injector upgrade that would help without doing any pump work. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 11:07am
A "stock" 200 tractor was 94 PTO HP.   There never used to be a problem turning out the torque screw several turns (or removing it and replacing with a plug) and getting 115 PTO HP. Takes 5 minutes to do. This assumes your pump and injectors are in good condition. More HP comes from more fuel. A better turbo won't change things much if any. Same for injectors unless yours currently have plugged holes.  Increasing the high idle really helps on forage equipment performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparks farm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 11:13am
So is the torque screw on the outside of the pump? I read on another forum that you have to take the top off the pump to get to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 11:31am
The torque screw is external and located just above where the lines attach to the hydraulic head. It sticks up/out at a 45 degree angle and has a plastic cap on it that unthreads. A 7/16" wrench and an allen wrench to adjust it OUT. Just remove the whole thing and adjust it 3 or 4 turns and replace. Swinging room isn't much on the pump. Removal of the pumps lid and governor guts is for roller-to-roller dimension and if your torque screw change isn't enough, that's where you go next. Remember your cooling system and tight fan belts. A couple hundred more RPM really helps on a chopper !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 8:16pm
So, did you gain any ??
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 9:17am
Are you trying to pull a 2 row chopper with a 200 if you are you’re going to need around 150 horse on the pto
A 200 will handle a 1 row very good but if you double the material going thru the machine it’s gonna be very slow
We went from a 1 row to 2 row on a 7010 and it was a load on it
A 7045 or 8030 will handle a 2 row really good
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 1:25pm
What kind of chopper? I filled many many 20x70 with a 190XT3 chopping 2 rows with an 800 Gehl, and the neighbor had a 200 and a 600 Gehl and it was no challenge for either one of them, and hay was in 12ft swats. My uncle bought a 1070 to upgrade the xt in 79 and the 1070 couldn't hang with the XT especially in mud
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 1:53pm
It all depends on your population and corn height. Chopping corn in 1985 at 10,000 population is a lot different than chopping corn at 40,000 population. I've seen two row of corn taller than the tractor cab and 150hp could barely do. Go on the other side of the field out of the much chopping 6' tall corn and you had no problem and picked up a couple gears.
Edited by Allis dave - 26 Sep 2026 at 5:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 3:22pm
140,000??? 80,0000?
High yielding corn for grain is about 35,000.
I would hate to pay your seed bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 3:48pm
There's alot i don't know but that doesn't make sense to me either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 4:33pm
I think back in the early 2000,s my Uncle used my 200 with a Jd 38 2 row chopper- doing corn and millet mix- run in 3 rd- but also had a new engine and fuel was all redone- average corn - itd make it work- but thats what they are made for
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 5:35pm
Originally posted by Allis dave Allis dave wrote:
It all depends on your population and corn height. Chhopping corn in 1985 at 80,000 population is a lot different than chopping corn at 140,000 population. I've seen two row of corn taller than the tractor cab and 150hp could barely do. Go on the other side of the field out of the much chopping 6' tall corn and you had no problem and picked up a couple gears.
Holiest of crap!!! Do you did you plant those corn populations?! 40,000 would be a LOT from anything I’ve ever seen.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 7:14pm
Corn planted 140,000 around here in this sand would only grow about 8 inches tall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 5:36am
I mixed beans and corn together in my head... I have spots the company that sets up my variable rate has 30-35k set. I don't have prime ground so I bet guys out in ILL are planting 40k now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 10:20am
I would think 40k in 30 in rows would be about like point rows where you got nothing but fodder.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 5:14pm
I used a Farmall 856 non-turbo with a Gehl 800, 2 row wide, population in lower to mid 30,000 range. Some years all could see was the very top of the Gehl 920 forage wagon, and of course the smoke from the tractor. Low range, 2nd gear, sometimes Low 1st but not very often.
Keep the knives sharp, set the cutter bar properly makes a tremendous difference.
Edited by Lars(wi) - 26 Sep 2026 at 5:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 6:17pm
Our silo filler was a neighbor and he always had a newer Deere chopper. He would touch the knives everyday to keep them sharp. Didn't take long to do, but he was pretty anal about doing that.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 6:44pm
During the 1970s-80s, our neighboring dairy farm used a NI self propelled 3 row 30” corn chopper for their silage & also did custom work for my Dad’s cow calf herd’s pit silo filling. That NI had an AC 426 (3500?3700?) that was heavily fueled up with a loud straight pipe exhaust. When running silage wagons, if you didn’t here that chopper, you’d only need to look to the sky for its exhaust smoke trial to know where & which direction it was headed. Yeah operator sharpened its blades religiously. It was one corn eating machine.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 7:37am
About 8 years ago, I had the engine in my XT rebuilt. Inj pump Ed rebuilt the pump and injectors. Whatever he did to the pump and injectors on that, is what you need to have done to your 200. Then she would chop corn!
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 7:54am
He hasn't been on here since the day he posted the question. Must be getting along fine....or he blew it up ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 11:55am
Darrel
Agreed. Sparks farm’s last quote, ”is there a turbo or injector upgrade that would help without doing any pump work. Thanks,” makes me wonder? Does his 200’s fuel system need a thorough cleaning / repairs of its injector fuel lines? Injector tip spray holes?, Gunky injection pump?, etc..?
Edited by AC7060IL - 27 Sep 2026 at 11:56am
