Allis B, C & CA Fitment
bigstone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Topic: Allis B, C & CA Fitment
    Posted: 05 Sep 2026 at 7:58am
Are the torques tubes with the starter hole on three models interchangeable?  Your help would be appreciated. s
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2026 at 8:01am
yes.. the torque tube and engines are interchangable... Few more taped lug holes on some, but all will fit........... transmission / rear end / final drives are different on the CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigstone Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2026 at 8:19am
Thank you Steve.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2026 at 9:28pm
Late model B torque tubes and CA torque tubes are exactly the same.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2026 at 9:47am
I don’t think the B has the 4 tapped mounting holes for cultivators.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2026 at 9:53am
I have a B torque tube in my garage with my bench grinder mounted to it. It is the right height and heavy enough that it doesn’t move.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 10:11am
I have seen several late production Bs with the CA tapped cultivator mounting holes in the torque tube.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 10:38am
The CA is about 5 inches longer than a C, is that entirely from the rear end?
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2026 at 11:58am
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 7:58am
the differential case  has 4  bolts that hold the final drives to each side.. The finals on the B-C are completely vertical to the case... the CA has the final cases turned slightly so the finals tilt BACKWARD somewhat.. giving a longer wheel base..
The troque tubes go by DATE.. The early B and C are identical and have no mounts for the implement... When the CA replaced the C, they added 4 tapped lugs to each side to hold implements under the tractor... at that point the same torque tube was used on the B which was still in production.
Edited by steve(ill) - 09 Sep 2026 at 8:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 8:08am
you can see the LUGS on the side of the torque tube... and the angle of the final drive mounting.
Edited by steve(ill) - 09 Sep 2026 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 11:34am
I just now did a crude tape measurement of my CA and Model C transmissions, the CA 4-speed transmission is a smidge more than 1-1/2" longer than the Model C 3-speed.
The majority of the length increase is from the rearward angle of the final drives.
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2026 at 1:49pm
The CA is also an inch or so longer in the front support casting as opposed to a C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2026 at 8:34am
Is this only from the increased length of the cultivator mounts protruding to the front, or does this actually increase the length of the wheelbase?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 5:00pm
The bolt hole bosses coming through the radiator shroud on the CA is the only change. The front support casting is interchangeable between the C & CA if the radiator shroud is modified on the C to clear the bolt hole bosses.
