Allis B block |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 475 |
Topic: Allis B blockPosted: 16 Aug 2026 at 3:37pm |
The engine for my B is a BE block. I am going to rebuild it soon. Can I use the 3.375 liners for the CE engine in it instead of the 3.250 liners?
'41 Allis B
'49 Farmall Cub |
Joined: 11 Sep 2009 Location: illinois Points: 93367 |
Posted: 16 Aug 2026 at 4:11pm |
almost all aftermarket kits are a slight OVERBORD of the new liners and pistons... These will all go into the original CE and BE engine blocks..
john2189
Posted: 16 Aug 2026 at 4:45pm |
Thanks.
'41 Allis B
'49 Farmall Cub |
Posted: 16 Aug 2026 at 5:04pm |
i did a Google search of posts on the internet, and this is the SUMMARY... I have never heard of an "early B block" that had a different sleeve bore than the later ones.. FWIW..
AI Overview Yes, the aftermarket 3.437" (3-7/16") overbore liner and piston kits will fit the older Allis-Chalmers
BE engines found in early B tractors. The BE (116 cu. in., 3.250" stock bore) and the later CE/125 cu. in. blocks share the same external architecture and wet-sleeve outer dimensions, allowing you to drop the larger sleeves and matching pistons right in. Important Installation Notes
Edited by steve(ill) - 16 Aug 2026 at 5:06pm |
