Allis 190 need speed. |
200 allis
Joined: 11 Mar 2014 Location: new jersey Points: 203 |
Topic: Allis 190 need speed.Posted: 07 Sep 2022 at 6:21pm |
Looking for more wheel speed, currently running 8th gear with cut tires 18.4x38 20" width rims. Not lacking power just need lil more speed. Whether tires 20.8x38 would be better or gears?
Posted: 07 Sep 2022 at 8:08pm |
Change bull gears and bull pinion gears to D-19 and gain 8%.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5326 |
Posted: 08 Sep 2022 at 5:55am |
42" tires?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5488 |
Posted: 09 Sep 2022 at 6:26am |
Most that switch to taller tires, don't have the power that they thought they had. Jumping to 42" tire from 38" is more of a ratio change that most think.
When you get into overdrive gearing, a small ratio change makes a big difference. The The D19 final drive gears sounds like the low cost option for a gear ratio change.
Find a pair of 20.8X38 to try first. |
brad7066
Posted: 03 Oct 2022 at 8:00pm |
atlas can make you gears
Gerald10
Posted: 25 Sep 2025 at 7:54pm |
Dr allis. Would this work for a 180. Need more speed in 3hi
Posted: 25 Sep 2025 at 8:07pm |
190 or 190XT or D-19 final drive parts do not interchange with a 180 or 185.
