Air fuel ratio gauge? |
Mnesler
Joined: 08 Oct 2021 Location: Houston mn Points: 11 |
Topic: Air fuel ratio gauge?Posted: 24 Jan 2022 at 9:16pm |
Just curious about using a air fuel ratio gauge for tuning a pulling tractor. Do many people you them or just tune using a dyno? Also are you looking for 14.7:1 or a little richer or leaner?
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5435 |
Posted: 25 Jan 2022 at 6:45am |
I run EGT gauges on my pullers to keep the A/F in the ball park. It's work for me for close to 30 years.
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 25 Jan 2022 at 10:16am |
We have one on a tractor they dont seem to
Last long. Like to be a little richer What are the temp you like to see on your EGT gauge on a gas motor? PaulB. |
Mnesler
Posted: 25 Jan 2022 at 1:05pm |
What temps are you looking for? I assume cooler temps = richer
PaulB
Posted: 25 Jan 2022 at 6:21pm |
You are correct; cooler exhaust is richer, hotter is leaner. I only run E85 is my pullers with spark plugs which tends to run a bit cooler than gasolines. With that I try to be in the 700-800 range. For racing gasoline, I'd think around 900-1000.
