Agco pulling tractor engine ??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Agco pulling tractor engine ??????
    Posted: 25 Feb 2022 at 1:52pm
Im bored   ,,Tossing around ideas of putting together an Agco puller, curious on ideas of an engine that will fit the bill for around the 8500 lb class - pro stock,  something that can be built for some what reliable - go with Detroit, Deutz or Navistar ? Im sure there will be out side of the box questions - just wanting to know of expericence , if any, thanks for any info
Edited by DougG - 25 Feb 2022 at 1:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2022 at 5:02pm
Real Pro-Stocks are single turbo (unlimited size). 24.5 x 32 tires, 680 cubes max and 10,000 lbs. The brand that dominates this class is John Deere big block power.  When you say 8500 lbs Pro-Stock are you talking a 4.1 inch turbo inlet  and maybe 466 max cubes???
Edited by DrAllis - 26 Feb 2022 at 7:49am
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2022 at 5:54pm
Mr. Doug G you ask alot of questions and ideas for all your projects have you got any complete?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 12:34pm
Why thanks for being very obsevant ! Always like these girs ,, lol,, Yes I have got a sweet XT , One Eighty, and D21 all up and going , I doing ask alot of questions and always like to hear what ppl have done ,as expirence is key - have got great advise from you - thanks - for that, I always like to do all I can myself - I never give someone an open checkbook like others do , Ill always be true to Allis - but gotta stay competative too, as in Agco Allis, this pulling forum gets boring with nobody posting ,,, so thats another reason I ask questions and will be posting alot more !!!!!! Get ready !!!! LOL
Edited by DougG - 26 Feb 2022 at 3:06pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 7:02pm
I see a lot of talk about using Cummins and Detroit engines in pullers. Do Pro Stock rules allow using engines other than original equipment ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 7:46am
Most of the National organizations do. Cummins and Dertoit series 40 (which is 100% a Navistar engine) were used in new AGCO/White models and therefore are called a replacement engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 2:56pm
This would never be in the national stuff,, just in Mid Missouri fellas, that big money is spent dumb  = unless a tax deduction !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 4:56pm
But, you've never specified WHAT Pro-Stock class??? 466 cubes with 4.1 turbo inlet at 8500 lbs ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:21pm
For 10k pro stock I would use a 40 series like that’s In The young tractor to my knowledge that’s what they are using. Correct me if I’m wrong.
If it’s a 540 CI class I would try and stay with AC because I’m a true ac guy. That be a allis 426 block dt466 crank “5.35 stroke” and a 4.625 bore with a recast head if allowed.
That’s My 2 cents
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:52pm
   I know of a guy that made a N-7 engine into a super farm puller, stated he could get head to flow over 400 cfm on flow bench, doesnt get much better.
   What about Sisu???
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 8:03am
My preference would be the 8.3L Cummins, Kevin Engleking is getting his White Ltd Pro dialed in pretty good, and Bob Himes has a recast head for them too. I like being a little different, most are going to the "detroit" just an IH engine lol! The Detroit 40 series that were used in Agco Allis tractors is a very different engine than the older International Harvester design. Many are just running an IHC engine not the Navistar/Detroit version. Proven, yes, just like everyone else, no thanks lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 8:07am
Ed is any information on the 8.3 for the bottom end? Knew earlier days they had issues keeping them together with high combustion pressures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 8:18am
The Detroit series 40/Navistar engines had a much different cylinder head on them. Intake air went in the top of the valve cover and no intake manifold on the left side. So, my question is are those newer Navistar engines bolting on an older IH cylinder head ?? Or are they using the newer design head that came with the engine ??
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 11:45am
A 466 IH head bolts right on. All the important things line up, but not all of the water jackets. That's what I run. I have heard of a few guys working with the factory style heads and they are starting to get some good numbers out of them now though.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 12:23pm
Good to know. I always assumed the head bolt pattern probably stayed the same, as it seems a change like that affects the build cost of any new engine Your engine is metric hardware, correct ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 5:30pm
Yes, 40 series is metric hardware.
brad durst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 6:52pm
so is the bellhousing pattern the same on the dt 466 and the 40 detroit the. if you had  both engines setting beside each other with the dt 466 head on how do you tell the difference. thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:06pm
I remember the injection pump sitting up much higher on the Detroit series 40 (and it's Navistar brother) from the early to mid 1990's. The MW in-line pump was almost as high as the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:18pm
thanks. can that all be changed buy bolting the front plate and timing cover of the dt on the 40. or does that require machining
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:25pm
Don't know. I seem to remember an extra idler gear in the front end to get the pump raised up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad durst Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:40pm
oh ok. do you know if the bell housing is the same. crankshaft bolt pattern ect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 12:37pm
The IHC engines did use an MW or A pump, and pump rotation was CW. The new generation Navistar engines, which is what the Detroit 40 series is, as well as Perkins 1300 series, all I've seen had a P pump and it is CCW rotation, and mounted up high. Obviously this pertains to the PLN (pump, line, nozzle) Systems. In Navistar branding, it was offered in 408 (school busses) 466, 530, 570 CID. In 40 series branding, I have only seen 466 and 530. Sorry Brad, I do not know if rear of engine is same as IHC engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 8:35am
They do, I run a custom front cover to put the pump down in what I call a "normal" spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 6:33am
Went to the Cowtown finals yesterday- only Allis there was a D 21 and it had a 5,9 Cummins- seemed an 8,3 L would be better in that one, but there again, not sure of the class as they did not go in the pulling order of itinerary and the cubic inch limit may have been close with the 5,9
Edited by DougG - 20 Mar 2022 at 6:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 7:01am
What class was it ?? Small Cummins gets used in that 410 cubic inch or less class. 8.3 is too big.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2022 at 9:33am
To clear this up - it was the 6000 light pro field class 361 ci engine limit, so the 5.9 Cummins was perfect- just seeing a 21 I was expecting a bigger engine- and sometimes i type before i think ! Lol,
orangefor life View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangefor life Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:21pm
Dr Allis
   Would you have tips on my 190xt  to boost the power. Looking to pull in the farm classes.
Just stock off the farm. What the biggest inj nozzle can i put in the 301ci an maybe teak the pump a little
                                            Thanks I watch you talk  an have enjoy listening to you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 8:30pm
I'd have more questions, but I'll tell you what I did for a friend back in 1977. He had a series three 190XT that he farmed with, and he too wanted to do a couple of county fairs thru the summer months. I installed a set of 7080 injector tips (set at 2500-2800 psi), bottomed out the leaf spring inside the injection pump (done by removing the pumps top cover) and turned up the high idle to 2800 RPM. Now, he still used it on the farm like that. We would turn the torque screw in to bring it down to no more than 100 HP at 2,200 RPM. The extra high idle was never used on the farm, only on the track. He got along fine and never tried pulling equipment any bigger than what he already had.  It's been a long time, but I think it would dyno 150 HP set up like that. Since those early days, I have made several water/alcohol injection systems, spraying the mixture into the air stream inside the air cleaner can. Out of sight, a trigger switch on the throttle so it turns on when you go the last inch on the throttle lever. That was usually good for another 30 to 40 HP.   In the 80's I set up a One-Eighty with a pump and injectors made for pulling. He would swap those parts every summer and then swap back in the fall with the farming parts. Turbo was off of a 200 or 7000 tractor and it stayed the same year round. Water/Alcohol injection was used too.   We felt his probably ran 220 to 240 HP.I also had another customer in the 1990's that we just turned his XT up to similar numbers (130-140) and he managed to rip the transmission to pieces because he was sure he could manage all the Xtra power without issue when farming with it.  I can also tell you stories of people who went to all the work to make the engine run well and get to the county fair and have the foot clutch or power director clutch slip and make zero use of the Xtra HP they added. It's a hobby I have participated in for 50 plus years and most of the time enjoyed it.
Edited by DrAllis - 03 May 2022 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 8:57pm
Then, there was the time when I was an A-C company rep that I "loaned" my own DM-4 pulling pump and four-hole .020" injectors to a dealer that he installed on a 7060 with a fresh/tightened down torque limiter. Tractors owner wanted to beat his Father-in-law's John Deere at the county fair in front of a crowd. Mission accomplished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangefor life Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 5:36pm
Thanks for ideals sound like i try some of them your the man.
