AC 917 Hydro
Jrbing13 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrbing13 Quote  Post ReplyReply Direct Link To This Post Topic: AC 917 Hydro
    Posted: 16 Mar 2024 at 2:59pm
I recently brought my dad's old AC 917 Hydro back to TN. It has a 42" mower deck and a rototiller. The tractor hasn't ran since 2015 but was always stored in a clean dry environment. I took it to a small engine repair person in the hopes of getting it running again. I believe my dad purchased this in 1979 or the very early 80's. It has a Briggs and Stratton 18hp horizontal engine, industrial commercial grade, cast iron bore. If memory serves me, it originally had a twin cylinder engine but I remember my dad taking it back to where he bought it because there were problems with it and I'm pretty sure they replaced it with this Briggs. I don't have any of the paperwork for this tractor like the owners manual, parts list, etc. I bought a new battery for it and the mechanic says the engine turns over but it needs a new ignition coil and likely a voltage regulator. That's what we know is wrong now, I'm sure there are other things that will need to be replaced just due to age and wear. My question for you experts out there is, do you know where I might find a manual for this thing and any other materials relating to parts. Any help of course is greatly appreciated. Thanks
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 3:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 9:41pm
Welcome to the forum. Just remember if you get an original allis parts book the part numbers listed won’t help you. You need simplicity part numbers. And if not original engine the parts book won’t help with those parts. If engine has tag with serial number and spec number, you can look some up that way.
Good luck
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 10:27pm
Simplicity is the route to follow for original parts. As mentioned the engine tag is what you will need if engine parts are required no matter the brand.
I had a couple of 916H tractors and always liked them as a heavy built unit. Newer tractors with foot operated direction changes were nicer and easier, but the times have changed. The 900 series were right to the point of needing power steering being that heavy on the steer axle although the 917, and 918 were lighter citing the aluminum cylinder block(s).
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 6:58am
If you don’t have a dealer you work with we can help locate parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrbing13 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 8:41am
Thanks so much!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jrbing13 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 8:42am
Yea, I was told Simplicity was the way to go with parts. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2024 at 6:27pm
I have a 917H and it came from the factory with a Kohlor Twin 17 series II. Engine swaps are common and as said above go by the engine tag for parts not the tractor itself.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2024 at 10:26am
917 here with an 18 in it. its a beastly thing! came with 5 attachments but I dont use it anymore. too many sunstars with power steering got in the way! lol! Tillin is done by IH 504 and cultivating by Horse tillers. Did just get a Simp. front ender tiller, also have a Simp. 7016 rear ender that I use a lot.
