AC 840 WHEELED LOADER TRANSMISSION
WELJ31 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Topic: AC 840 WHEELED LOADER TRANSMISSION
    Posted: 13 Apr 2025 at 9:12am
Hello
I live in northern MI where ice storm just hit. We are trying to get clean up going and ran into a problem.
I did a search and found nothing.
So I am iso information on a older AC 840 wheeled loader. Should be basic information. I have the operator , service and parts manuals but cant figure this out.  The pics in my manual are not clear. I was trying to check the trans fluid level. The trans pan has two pipe plugs on the front. One high and one low. My understanding was to pull the top plug to check fluid level. Well that resulted in about 2-3 gallons of ATF coming out all at once.
1) Is this actually how to check the level?
Manual states open valves ???
I have no idea what that means. but pic has a caption saying plug?
2) Manual says Dextron fluid?
Thanks for any help
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 7:10pm
I am not familiar with your loader, but it was very common to not have dip stick until the 1960's.
I have mid 1950's AC crawler that you pull a plug on, the next size larger crawler built at the same time has a dip stick.
I wonder if they meant a bolt like plug that has been drilled so turn it out just several turns and it can drip out just enough to say it has fluid. You never turn them so the threads are all the way out of body. John Deere used that kind of thing on the 2 cylinder Jonny Poppers. I know very poor description. Hopefully jog someone's memory and they will have a name other than valve.
Brad in WA View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2025 at 10:23pm
John, I've had an 840 loader for 30 years. Yes the oil level should be to the top check plug. If yours was overfull it's possible either the steering or loader hydraulic pump is leaking hydraulic oil into the transmission, thru the front seal. I had this years ago, putting a new seal on the steering pump solved the problem. It's the same seal as a 190 tractor. Be carefull when you slide the pump out not to drop the adapter drive sleeve into the tranny. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 8:39am
Thank you  that appears to answer my questions.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 6:49pm
Just out of curiosity is the transmission oil to be checked hot or cold and engine running or stopped?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 3:06am
It was cold not up to temp. I know should have been running.
What type of fluid are you using? Manual says Dextron atf
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 6:44am
what type of fluid are you running?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 7:59am
I know the manual says Dexron ATF, but I've been using a good hydraulic oil. Check with engine idling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2025 at 8:03am
I really appreciate the help
So if its leaking hydro fluid into trans is there any danger to the trans?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 3:50am
I don't think a little overfull would matter but I wouldn't let it get too full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WELJ31 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2025 at 8:38am
How big of a job is that (seal) and will it harm the trans if not fixed right away? thanks
