AC 8050 don't disengage clutch and no trans.brake?
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Topic: AC 8050 don't disengage clutch and no trans.brake?
    Posted: 15 Jul 2020 at 1:48am
Hi everyone
When I step on clutch of my 8050 tractor, it does not disengage and keep on moving.
It also do not have any trans.brake when I push the paddle all the way down.
The mechanical part seems to be doing its job pulling the hydraulic piston out, so what else could be wrong?
Thanks for your time
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 6:25am
PS or pd?             MACK
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 11:36am
POWER SHIFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 12:08pm
Broken off piece of fork lodged in the inching spool.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 3:15am
Not sure where what and where the inching spool is?
 Is it inside the wet clutch at the plates?
 As I mentioned it also does not have trans.brake when the clutch paddle is fully pressed down?
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 3:27am
It's as if the oil can't go to the dump port nor the trans.brake port.
Could something be blocked up and prevent oil from going where it should?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 4:26am
it is in the valve body on right side behind batteries.        MACK
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 3:38pm
Thanks MACK, I think I know now what Doc is talking about.
If I'm understand correct and the spool is the part that moves in/out the valve body, will it not be stuck in one position with the piece of broken off fork? I'm asking, because my spool is not stuck at all. It moves easy and all the way.
I have never been inside the valve body, could someone maybe explain how the inching spool directs the oil to clutch/ dump/ transbrake? Or maybe posts or sites or online manuals where i can learn more.
All I have is my logic, and that is telling me I have oil presure (tractor moves), but spool can't dump, or direct oil to trans. brake, all though it(spool) is moving.
My neighbor told me to press the clutch and then brake hard, while driving, to see if it will loosen up the clutch, but this is not a stuck dry-clutch problem and I'm to afraid to brake my torque converter plate AGAIN!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 7:00pm
The spool you see is external. It pushes against an internal and separate inching spool. The inside one is the one that is stuck because something has jammed it.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 9:13pm
Thanks DOC, I guess it's off with the valve housing then.
How much rocket since involved to do that?
Thanks again.
ANDRE
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2020 at 6:37am
Not too difficult if you are used to wrenching on farm equipment. You'll probably need two gaskets and a spool oil seal while you have it apart. Everything is aluminum so be careful. A service manual would be helpful. Everything externally must be adjusted right for proper shifting and kickdown and inching.  Bolt torques are kind of crucial.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 12:08am
Thanks again.
Yes wrenching is my thing!
I don't use cutlery when I eat in my Allis, only sandwiches, so I don't really know where that piece of fork came from!!Wink
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2020 at 9:15am
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2020 at 1:05am
Hope you can open this pic.
So this is the broken fork. I didn't find the rest of it?
What is the function of this stainless steel plate, why would it have broken and what would be my options on replacing it?
Thank for your time.
Andre du Toit
This page was generated in 0.605 seconds.
