AC 715 B tie rode ends
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: AC 715 B tie rode ends
    Posted: 30 May 2026 at 9:43pm
My care package from Herc U Lift came today with new tie rod ends . All the dimensions  look correct , and new ones even have ability to be greased as place for zerk
they ordered from Total Source using the AC part numbers
TSA / AC 1007069  / TSA /AC 1007070
https://www.tvh.com/parts/our-brands-partnerships/totalsource
Looks like they handle a lot of material handling equipment and are a parts source for lot of different companies .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2026 at 9:55pm
Seems they carry lot of parts that Min-Par use to supply - as listed as owned by Belgian parent company but US warehoused ? See they say they carry Perkins engine parts also
  https://www.tvh.com/en-us/parts/our-brands-partnerships
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2026 at 4:28am
Cat bought out Perkins, supposed to be able to access older engine parts thru them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2026 at 9:47pm
The tie rod ends were reasonable - but shipping seemed high -
Perkins after market parts or CAT parts unsure of cost difference .
Next I need to check the steering cylinder as it seems when on the road the steering wheel will end up making a full turn while driving straight - it seems to wander and as you correct it wheel ends up not is same position .
