AC 170-175 gear shift levers? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11125 |
Topic: AC 170-175 gear shift levers?Posted: 24 Oct 2026 at 7:36pm |
I have a different style lever on my 175 than the 170 have. The 170's have a shift lever that is tapered and has a ball on the end made on it. I know the rubber shift knob slides on it. The 175 has a non tapered shaft lever. Does the hard ball shift knob screw onto this shaft? I want to replace the shift boot. Thanks, Tracy
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 335 |
Posted: 24 Oct 2026 at 7:58pm |
My 185 has the hard plastic ball. It needs a metal ring/wedge to grip the ball and shifter rod. Andy
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7726 |
Posted: 24 Oct 2026 at 8:30pm |
x2. When I restored my 175, I used a pipe wrench to turn the knob back and forth until it came off. It didn't break, but did get teeth marks in it! When putting a new one back on, I put a piece of 2x4 under the gear shift, wrapped the knob in a rag, and tapped it on with a mallet. I don't know if the metal wedge is still available, I reused the old one.
