AC 170-175 gear shift levers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170-175 gear shift levers?
    Posted: 0 hours 60 minutes ago at 7:36pm
I have a different style lever on my 175 than the 170 have. The 170's have a shift lever that is tapered and has a ball on the end made on it. I know the rubber shift knob slides on it. The 175 has a non tapered shaft lever. Does the hard ball shift knob screw onto this shaft? I want to replace the shift boot. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 38 minutes ago at 7:58pm
My 185 has the hard plastic ball.  It needs a metal ring/wedge to grip the ball and shifter rod.  Andy
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 6 minutes ago at 8:30pm
x2.  When I restored my 175, I used a pipe wrench to turn the knob back and forth until it came off.  It didn't break, but did get teeth marks in it!  When putting a new one back on, I put a piece of 2x4 under the gear shift, wrapped the knob in a rag, and tapped it on with a mallet.  I don't know if the metal wedge is still available, I reused the old one.
