AC 170 , points and condenser |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11124 |
Topic: AC 170 , points and condenserPosted: 12 Sep 2026 at 9:01am |
What are the part numbers for these in Ecklin or Blue Streak or another good brand? What number plugs are you using, it has Champion N5C in it now.. I am away from farm, but wanted to take some with me next trip. Thanks, Tracy
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 5032 |
Posted: 12 Sep 2026 at 10:09am |
Tracy, these are Standard Ign / Blue Streak ![]() ![]() |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
ac45dave
Posted: 12 Sep 2026 at 10:31am |
EchLin points CS763
EchLin con RR174 " cap. RR145 " rotor. RR301 " dust cap RR164 Edited by ac45dave - 12 Sep 2026 at 10:51am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5475 |
Posted: 12 Sep 2026 at 6:15pm |
It hardly matters what box you buy, the parts inside will most likely all be made at the same place. Champion plugs are about the worst quality plugs available today.
Joined: 11 Sep 2009 Location: illinois Points: 93430 |
Posted: 12 Sep 2026 at 6:37pm |
most of the BLUE STREAK stuff was made in Poland or Japan ... Assume it still is.... Not the same as China stuff..
Tracy Martin TN
Posted: 12 Sep 2026 at 9:08pm |
Joe, thanks a million! Tracy
Tracy Martin TN
Posted: 12 Sep 2026 at 9:20pm |
I went to the farm early. Tried to get plugs in town, no one had any. No help at parts stores. Filed the points and sanded them. Not a hat spark at plugs like I wanted after Cleaning rotarty button and cap. Weak to me. Sprayed choke cleaner into intake, never a pop at all. Just had put carb back on, floods again. When I had carb apart, cheched float and shutoff height. Both were good. Only ting I notice is float needle seems to want to hang in opening. Polished it best I could, still wants to hang. This is the most aggravating carb on any of the tractors I have, it is a Zenith. Before the alternator -regulator failure, it started and ran fine , but carb flooding could occassionaly happen. Always shut off fuel under tank when not running it. Going to try to put a cut off right before carb bowl. About at wits end with this one. What do you think? Thanks, Tracy
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3276 |
Posted: 12 Sep 2026 at 11:31pm |
The steel tip needle valves are the only ones that always work right.
Posted: 13 Sep 2026 at 8:15am |
how about the COIL ?? when they get old and weak, you can get a Minimal Spark Condition...
Tracy Martin TN
Posted: 13 Sep 2026 at 9:41am |
My float and needle does not have the little keeper spring. It has the viaton tip on it. Have not checked the coil. Have to order everything. Thanks, Tracy
Kenny L.
Posted: 13 Sep 2026 at 12:24pm |
Tracy, if you would like I could fix you up with NOS tune up set. Kenny L.
Tracy Martin TN
Posted: 13 Sep 2026 at 6:50pm |
Kenny, message sent. Thanks, Tracy
Kenny L.
Posted: 14 Sep 2026 at 12:39pm |
Tracy, send you a PM
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6167 |
Posted: 21 Sep 2026 at 10:48pm |
The other thing to do... is run a wire from the battery directly to the coil, and another wire from the coil bracket to the battery negative. It is not uncommon for a weak spark to be from an ignition or ground wire that's got enough corrosion hidden inside to limit current to the coil. Sometimes, the ignition SWITCH has a lousy contact... and sometimes, the battery ground wire is rotten right in the middle, such that when you attempt to crank the engine, the starter pulls basically everything the battery has to offer... save for what the ground cable will allow. Plumbing, not Money, is the Root Of All Evil. Wires are PLUMBING for Electrons, thus, evil.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12081 |
Thanks(1)
Posted: 24 Sep 2026 at 7:27pm |
Blue Streak tune up parts are made in Mexico not China.
