AC 170 ground cable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 ground cable?
    Posted: 24 Aug 2026 at 3:26pm
I don't have my manual handy. Where was the original ground cable bolted to the AC 170 tractor? Mine at present is at the bolt thru the steering-dash column that bolts to torque tube near clutch pedal, close to rubber mount. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2026 at 3:53pm
i dont know the original location, but the main purpose of the battery is to crank the starter.. Ground should be as close the starter and grounded to the frame or engine block. trans case, etc.. Dont go thru 2-3 layers of sheetmetal..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2026 at 10:04pm
The cable is bolted where mine is now. Found my manual and it uses that bolt. I am making me a bracket for my battery disconnect to attach to tractor in that area. Thanks, Tracy
