AC 170 gasser parasictic draw?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 gasser parasictic draw?
    Posted: 22 Aug 2026 at 6:38pm
My battery is flat again. Brand new in April of this year. Rebuilt alternator and new voltage regulator. Voltage regulator does not have screws. No lights on it. I am at wits end trying to find it. What normally goes wrong? No problem before I rebuilt alternator and replaced regulator. Regulator post had fatigued and broke off. What you guys think? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 6:46pm
unless you have a wire that is corroded and laying on the frame rail... the only places to have a SLOW LEAK would be the starter switch,  starter, alternator and regulator.... You can pull the plug on the alternator  or regulator and let the tractor set for a couple weeks and see what happens.... just cause its NEW, dont mean it is GOOD..
Edited by steve(ill) - 22 Aug 2026 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 6:49pm
one good way to test is to remove the battery cable and put a small amp meter ( maybe 50 miliamps)  from the cable to the battery terminal... then unplug one thing at a time and see when the meter drops to zero..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 7:55pm
Steve, I will try this. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 8:35pm
most hand held volt meters have a small "amp" scale ... and will measure for milliamps
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 5:37am
Another option is to put a battery disconnect in the circuit. I really like them on my tractors that I take to shows, so kids can't engage the starter.
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 5:41am
12V test light in-line will do it also
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 9:20am
That's the way I test them; do set the meter on the highest scale at first.
My Grandson is working on a Ford 7600 that is owned by his boss, it was draining the battery after sitting for 2-3 days. The boss wasn't turning the key all the way to the OFF position and we measured ~ 500 mA of current draw (zero draw when properly shut off). Then we measured the charging amps while running and found that the puny stock alternator won't keep up with the air conditioning, much less with any lights on. This tractor has no ammeter in the dash, just an idiot light which doesn't work.
I have seen a faulty ignition switch cause parasitic drain, also an extremely dirty battery top caused by over-charging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 10:42am
Do you have an ammeter on the tractor ?
If so, the 'stepped fiber washers' can be become a parasitic drain.
I replaced them with 'new' plastic ones.
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 10:43am
I finally did that to all of my tractors and my grain trucks. I should have done it years ago.  It has saved me time and money, batteries are lasting way longer and it gives me a piece of mind on electrical fires.  An added bonus is the ease in disconnect when working on electrical or welding on equipment hooked up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 7:04pm
The tractor is at the farm. I live 20 minutes from it. I would like to find the drain, but I don't have the time at present. I bought a Cole Hersee disconnect. Going to make a bracket for it this week. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 7:52pm
Where did you find a disconnect worth a crap?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 11:17pm
Cole Hersee is the brand, I got it at Oreily's. They ain't cheap. But these are the best. You can get them on Amazon and eBay, just make sure it has the Coile Hersee trademark stamped in it. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2026 at 5:23am
Grote is another quality switch.
