Abandoned HD21 |
Page <12345> |
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 07 Apr 2013 at 2:37am |
Taking blade off looses a lot of weight. If that structure hanging off the side of the bridge is not the local DOT office, I`d be tempted to drive the tractor over it
Lazyts
Posted: 07 Apr 2013 at 9:25am |
Gordy- I've purchased two HD11 tractors that did not steer- turned out to be a plugged inlet screen on both of them- wouldn't hurt to double check if you haven't already.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12081 |
Posted: 16 Apr 2013 at 10:29am |
Been following along with this story myself. Pretty interesting for sure! I was thinking the same as MacTractor was. I don't know much about Dozers other than they're super heavy and I've been working on a few our ours here at work on occasions, (D7G, 955, and JD650) but I would think that if you put that Dozer on a diet and remove the rear winch and front blade, and whatever else that could be removed to lighten her up, you just may be able to go right across that bridge wit dat big dude! Yeah, the bridge looks a bit scary at first, but looks to me that under all that moss n' stuff, it looks like a pretty stout & riveted bridge. After all, the Dozer got in there, put her on a diet, and lighten the old girl up n' git er' outta there!
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34726 |
Posted: 16 Apr 2013 at 1:50pm |
I was thinking if you would lay more long heavy timbers on top to increase the load bearing capacity while it went across, making sure the timbers are supported over the bridge supports... then remove the timbers and not affect the bridge to any extent.
I know, it's easer to think it than the fact of being able to do it...
My first though was if you laid couple semi trailer flat beds down to cross on.
Or if there was a lesser embackment and was able to drag the crawler across from the other side with a bigger cat and winch...
Good luck. and keep us posted of whats happening.
sandman2234
Posted: 16 Apr 2013 at 3:26pm |
Just wondering if there is anyway you could get another crawler with winch in there and a short section of railroad track to cross the river. Skidding it across steel tracks might be easier than dragging it thru the mud or across trees dropped to cover the water. If running, driving it across rails would be possible IF the crossties were long enough to allow another section of rails to be added outside the standard gauge width. Several sections of rail side by side with crossties or even steel welded under them to hold him in place so they don't twist might give you a temporary bridge. If you can get another crawler into there, to help move the "bridge", it can also help pull the other up the embankment on the other side. Not sure how long you are talking about, but rail comes in some pretty long sections, and a good friend at the scrapyard might be able to hook you up for a loan of some. (Not suggesting this, but I do see it all the time pulled and dropped on the right of way) A connection at the railyard might get a loan of some worn out stuff long enough to do this.
I would be scared of attempting to cross the existing bridge, because if it fails, you loose the Allis and you might get charged for the repairs of the existing bridge. Plus you would sure make a lot of people mad (the ones that currently use the bridge). It is easy to sit in Florida and dream of ways to move this monster, but the bottom line is, GOOD LUCK AND BE CAREFUL!! David from jax |
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1025 |
Posted: 17 Apr 2013 at 1:26am |
ACcrazy: You have raised so much interest in this thread that with some sponsors you could likely start a TV series ......... "Rescue the HD21". If the bridge would crash the ratings would simply go up, LOL
ACcrazy
Joined: 30 May 2012 Location: Eureka, Califor Points: 97 |
Posted: 17 Apr 2013 at 9:41am |
EricB lol. Just send me money, machines and a crew; we'll get 'er rescued!
Appreciate the suggestions on getting across the river guys but I'm fairly certain it will have to walk out under it's own power. From my perspective I have a couple choices. 1) Do a little blade work and cross the river at a shallow spot, which I think can be done in the summer when the flow is at its lowest volume. 2) Walk it out a road I found on Google Earth and come out on Thompkins Hill Road, which is a stones throw from Highway 101. But first things first. I still have to see if the engine's free. The land owner is out of town for a month so I'm gonna have to wait until she's back before I'm able to monkey around with it. Cal(KS)- Thanks a bunch for the offer on engine parts. I may be taking you up on that. Edited by ACcrazy - 17 Apr 2013 at 9:43am |
Mikez
Posted: 17 Apr 2013 at 3:28pm |
Is that how she got into there. Was the place logged, is that why it was in there to log the property. Sorry first time reading this post. How much does she weigh and has any of you guys had success in one moving after sitting that long. There's nobody in town like older guys that know the history of it and area. Good luck. I like the idea of saving her
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3812 |
Posted: 17 Apr 2013 at 4:51pm |
Ill try to do what i can from 1822 miles away.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 18 May 2013 at 12:13am |
Well, it's been a month. Any news yet? We are all anxious for good news!
Allis Express participant |
ACcrazy
Posted: 18 May 2013 at 9:08am |
Nothing yet, John. I'll give her another call later today.
FloydKS
Joined: 12 Sep 2009 Location: S E Kansas Points: 8749 |
Posted: 22 Jun 2013 at 1:06pm |
bringing this one back to the top as it has been a while since this "call later today" post.
ACcrazy
Posted: 04 Jul 2013 at 7:25pm |
Happy Independence Day everyone!
Sorry for the delays here guys but I've been very busy with other duties as of late. I'm getting caught up but still much to do around the place here. I called the owner again today and left a message. Hope I get a call back this time. I know she has been busy with some legal back and forth with government entities over land usages so she may be a bit preoccupied with that deal at the moment.
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1020 |
Posted: 05 Jul 2013 at 3:58am |
Might be time to trial a flight of another TLA
FGE
ACcrazy
Posted: 18 Jul 2013 at 8:08am |
Well, she's not returning my calls. I don't know what the deal is but I guess it's time to move on.
JohnCO
Posted: 22 Jul 2013 at 5:39pm |
Pay her a visit? Take her some tomatoes or peaches, almost always works for me.
Good luck! |
CAL(KS)
Posted: 23 Jul 2013 at 9:57am |
I agree, a visit in person puts a face to the name and will make the seller more comfortable. They can hear your desire to fix the machine instead of soliciting a call from someone who may be just looking for iron to scrap.
ACcrazy
Posted: 24 Jul 2013 at 8:54pm |
Guys, I have met with her in person and walked the property with her. I know where she lives, basically, but the entrance is gated and a fair distance from her residence. I don't think she'd take to kindly to me jumping her fence and showing up at her doorstep.
I can't say what will happen in the future but we're taking a break for now. That's all I can say at the moment.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11132 |
Posted: 24 Jul 2013 at 9:16pm |
Drop her a card in the mail. Let her know you are the one that walked with her, and would like to save the crawler from scrap. HTH Tracy
JC-WI
Posted: 24 Jul 2013 at 9:51pm |
Tell her once you have it restored... or back up to running, she can go and have a ride on it and if so inclined she can even run it... Well that was just a thought.
Eric B
Posted: 25 Jul 2013 at 1:01am |
ACcrazy: I'm sure we'll hear from you again....you deserve to be complemented for having started the longest thread I've followed from start 'til now....6372 views at this point - Congratulations to you....you've caught the interest of many people!!!
GlenninPA
Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Posted: 02 Jan 2014 at 5:39pm |
6 months is a nice break..... Anything new to report?
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Lazyts
Posted: 03 Jan 2014 at 10:46pm |
Just thought I'd add these pictures of a 21 my father in law spotted while hunting a few years ago.
Eric B
Posted: 03 Jan 2014 at 11:45pm |
For us older guys this feels like a late model 21 .... far too new to be dismantled
. Looks to be all good 'til you get the side view
Lazyts
Posted: 04 Jan 2014 at 9:14am |
Probably started out as a repair job that never got finished. Looks like about 1975- it has the muffler. By looking at the blade, it did its share of work. I think it disappeared a couple of years back, probably cut up, but who knows?
ACcrazy
Posted: 05 Jan 2014 at 9:08am |
Thank you, Eric.
ACcrazy
Posted: 05 Jan 2014 at 9:14am |
Unfortunately, no. But this endeavor is still alive. I have turned the reins over to AC_Mel. I will help in whatever capacity I can but he has the resources to actually make this happen. I'm hoping to see this machine added to his collection in the future. :) Happy new year everyone! |
Gordy
Posted: 05 Jan 2014 at 12:01pm |
This one is still available for just a little above scrap price
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3815 |
Posted: 01 Feb 2014 at 11:24pm |
Great story.. What do these 21's weigh? What kind of scrap price will one bring? I sure hope you guys get that owner lady to cooperate... Does she know how many Allis-Chalmers followers are watching this from this website?? Good luck to all..
Eric B
Posted: 02 Feb 2014 at 12:18am |
Weight for the HD 21 is in the range of 57 to 60 000 Lbs. depending on which model and options. Certainly would bring some good pocket money as scrap-metal when the rate is at the upper peak. I know a guy that was trying to sell a perfect running condition Gradall, he was looking for a very reasonable price ..... no takers. He drove it down to the scrap metal yard and parked it ..... went home with a cheque for $5000 ...... was ready to take less from someone buying it to keep it in the work force
Page <12345> |
