840 wheel loader ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: 840 wheel loader ??
    Posted: 23 Jun 2023 at 3:46pm
I have an old friend who is looking at what he says is an A-C 840 wheel loader. It is powered by a 4-cylinder Perkins diesel engine (236 cubes I assume). He would like to know the rated lifting height and lifting weight of this machine. Any help would be appreciated. Thank you.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 4:44pm
Lift capacity - 9,000 pnds.
Perkins 4-248 Diesel Engine
74 net H.P.
1.25, 1.50 and 1.750 loader buckets
Torque Converter coupled to a 3 speed Fwd. Reverse Transmission
Planetary Rear Finals
Continued product development by AC produced the 840B  - Perkins engine evicted and AC 2900 turbocharged Diesel put in.
Produced in Deerfield Illinois and marketed by AC Industrial Tractor Division.  AC 840 and AC 840B dropped from production in 1976 after Fiat Allis came to be.
Replacement Wheel Loader was the Fiat Allis 345 and Fiat345B soldiered on in production until 1983.  Specifications similar to AC 840 and AC 840B wheel loaders.
Lift Height - ?
HTH's ~ Orangeman
Edited by orangeman - 23 Jun 2023 at 4:49pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 4:47pm
My friend is concerned about the lifting height to be able to lift a bucket of lime into a TerraGator spinner box. I think it might be just a tad low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 4:49pm
Will do some more digging on spec. lift height. ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 4:57pm
According to this site, the height @ 45 degree bucket tilt was 111 inches...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 5:07pm
Thank you very much. That should answer all his questions I think. The "B" series got the 2800/301 non-turbo engine at about 85 flywheel HP versus the 248 Perkins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 6:41pm
https://www.allischalmers.com/forum/840-wheel-loader_topic8666.html
yes  Perkins... then 2800 ..... then 2900 in the 940.
Edited by steve(ill) - 23 Jun 2023 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 11:22am
An 840B is on my wishlist! Could use it here for snow and topsoil work! ~  Orangeman
This page was generated in 0.234 seconds.
