8070 front driveshaft
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: 8070 front driveshaft
    Posted: 25 Aug 2026 at 8:14pm
Slip yoke on the FWA drive shaft has a lot of play.  I assume a good driveshaft shop should be able to rebuild?
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 6:20am
Probably. I'm pretty sure those parts are all metric, and they may have that available to them after 40+ years. Seems like in the distant past some American parts have been grafted in that area for repair work when metric couldn't be had.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 12:22pm
Agco still has it, not cheap but atleast you know it should be correct
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
