8.3 cummins in a 220.
Agcosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Agcosucks Quote  Post ReplyReply Direct Link To This Post Topic: 8.3 cummins in a 220.
    Posted: 31 Mar 2023 at 9:31am
Is it possible to put an 8.3 cummins in a 220? I can get my hands on an adapter plate. Any advice is appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 10:18am
Is an awful LARGE engine to shoehorn into a 220.  Best be measuring, A LOT.  It DRY weighs 1450 lbs, where even a 5.9L would be tough to squeeze in.
From a marine installer, Engine is 45"x30"x43".  Typically holds 3 Gal Oil.  500cu in
Edited by DMiller - 31 Mar 2023 at 10:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 3:15pm
I'll bet if you put a tape measure on both engines, you'd find they are very close to the same overhaul length, so an installation shouldn't be too tough. My genuine concern is the fact that the peak torque numbers are far greater than the driveline was designed for and if you so choose to use it in the field and weight it down, there could be trouble down the road. I'm thinking 450-475 ft lbs at 1400 RPM was what the 426 developed. Tell me why you wouldn't want to fix the 426 or replace with another 426 engine ??
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 5:43am
This is an 8.3 in an 8030. Stock fan and shroud using the Cummins spacer.
Edited by Jordan(OH) - 17 May 2023 at 5:45am
This page was generated in 0.081 seconds.
