7060 tie rods
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 tie rods
    Posted: 23 Sep 2026 at 6:03pm
Where or where not to buy?
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 5:44am
They are still available from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 10:43am
At better than twice the price, is there a reason for that?
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 11:55am
Sometimes you get what you pay for....Sometimes not. How's the quality on the cheap ones? Will it take 2 sets over time to get hours?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 2:39pm
If you have a part number try search engine for tie rod ends - or see if a match is there
I just went through this for my AC 715B TLB and ended up with a fork lift company that use to sell AC machines - NO they were not cheap but units fit and were greaseable where stock were not - should outlast me and rest of machine as believe ones were replaced were original to machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 2:45pm
  • OEM Part Numbers: 70265527, 265527, 70265527V [1]
  • Specifications: Length of 4.946 inches, diameter of 1.125 inches, and right-hand (RH) thread.
    Google search comes up with several matches and several prices .
    https://www.worthingtonagparts.com/allis-chalmers-tie-rod-outer-new-wn-70269353?srsltid=AU7gw4VSVYEo0KiLIxRhhbn6SKV2TX1Kdkq74O0yGvHuXelm02rZTwgR
  • Life lesson: If you’re being chased by a lion, you’re on a horse, to the left of you is a giraffe and on the right is a unicorn, what do you do? You stop drinking and get off the carousel.
    rw View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 9:14pm
    I was sold a will fit and the right end is different from the original factory end. The original has a slot in the socket that the ball stem comes through. The slot fits tight and keeps the tie rod indexed to the steering cylinder. The aftermarket set up lets the tie rod twist when you turn and the steering cylinder eyes rub on the mounting brackets.  Works ok, they said it was all you could get for parts, its been on there several years, still works ok, but i wish it was like the one that came on the tractor.
