7060 pd vs 8050 ps
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: 7060 pd vs 8050 ps
    Posted: 10 Oct 2026 at 7:06pm
Our 7060 is an early power director model. It's our hay making, poo hauling tractor... bin in the family since new. Would we be happy with an 8050 power shift or do I need to look for an 8070 and do the pto conversion. As duel pto is a must!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 6:27am
I've got a 7060 powershift, and had an 8050 powershift (until it burned up), and I always thought that they were pretty comparable
Darrel
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 9:48am
Todd, I doubt either one of those jobs is working the 7060 to it's full capacity, I'm sure an 8050 would handle them well too. You may not like the laziness of the M100 governor though, but a PS will let you keep it wound up.
Edited by injpumpEd - 11 Oct 2026 at 9:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 10:41am
We bale with a vermeer 605m 5x6 baler. We put new belts in it this summer and it will make the 7060 work. Know keep in mind we are talking north of 16000 hours on the ole gal... so im sure she's tired...
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 11:01am
Friend of mine has a 7060 PS and i have a 8050 PS, never noticed much of a difference between them power wise. Seems to me like the 7060 has a little less engine noise, a little more responsive, and might smoke a little more but nothing crazy noticeable. Never ran a power director but love the powershifts. We use our tractors for everything, tillage/planting/hay/manure and the powershifts work great.
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 11:24am
An early maroon belly 7060 would have the very reliable good/simple floor gear shift. So no cable issues for it.
Your 16,000 hrs 670I, PD, dual pto, etc combo speaks for itself.
Someday I may own an 8000 series? Think, I’d love their comfortable roomy cabs. Or, maybe just install an 8000 cab onto my 7060 cause I love its throttle snappiness & very good torque.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 7:17pm
Now deceased neighbor charged the front plate and used a 7030 or 7050 pump on his 8050.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 7:18pm
Going to a Powershift is a huge step in the right direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 8:31am
I also built a DM pump for a customer from this page who has several 7060's and one 8070, and he didn't like the laziness of the M100 governor, so he swapped all the parts over to put the DM Roosa I built for him on it. Several guys swap an A pump to them, but I haven't had the time to be involved with those.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 10:40am
The biggest drawback to the powershift is there is too big a jump between gears for some applications. Under heavy load like a forage harvester or plowing it can be a bit limiting. I always wondered why they didn't mate the 2 speed from the power director to the powershift to split each gear. That would have made a huge improvement in performance and probably reduced issues due to lugging the engine. Probably too expensive at the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 11:23am
Placing a "Power Director" 20% speed changer ahead of the PST couldn't be done for one thing. If you've ever seen cut-away pics of each transmission, you'd see why. A 20% split would have just seen to it there would have been multiple gear choices that in the end just gave you two gears that were the same speed.  Cost would have been too much. Their only option (and they were working on it) was a 3-speed range transmission, with the "medium" range placing 5th gear at the 6.0 to 6.2 MPH speed and everything else just fell in where it may. Now, we are talking 1985 was the end. The Case-IH Magnum tractor came out in 1987 with the first "counter-shaft" 16 speed PST. Deere had already had their 15-speed planetary PST since 1983. The A-C design just didn't/couldn't ever become a "full" PST non-stop shifting from top to bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2026 at 11:53am
A 7010-20-40 PST with 18.4 rubber gave you PST low range speeds of 1.8-2.5-3.5-4.4-5.4-6.8 mph.  For almost all selections the change is approx 18%.   A-C did provide a "fast" low range in the last of the 8000 series. The increase was approx 11%. This then yielded speeds of 2.0-2.8-3.9-4.9-6.0-7.6 MPH with the same rubber.  So, as you can see, they lose a low gear of under 2 MPH, which in some parts of the country was a big deal. But for midwest farming applications, they gained that desired 6.0 mph tillage gear. I believe their next planned transmission was to be (as I said) a three-speed range transmission that would have had both of these range selections and left high range the same. It would have been pretty nice, but already outdated to the competitions full power shift designs.
