7060 hydraulic filter light
timmiso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmiso Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hydraulic filter light
    Posted: 09 Apr 2019 at 9:36pm
Ok back at this thing. Basically a junkyard tractor that I’ve got most of the stuff fixed - just ac and this filter light to figure out.
New filters installed correctly (I believe) screen in on left side, spring in on right side. Cannot get filter and temp light off. (I think they’re together to check when starting). Book says it’s just a ground plate that should lose ground when the oil pushes the plunger off the seat therefore shutting the light off. What am I missing? I ran new wire from idiot light down to sender - still nothing. Wondering if the spring was changed at one time? Am I understanding it correctly that the incoming line is the one with the sender on it, and it goes thru the filter to return? Can’t wait for the rain to get out of here and to try it out doing some pulling.
Edited by timmiso - 09 Apr 2019 at 9:38pm
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 11:25am
Go to the filter housing. Pull the lead off the sending unit. If the light stays on the lead is shorting out.
Edited by exSW - 10 Apr 2019 at 11:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmiso Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 12:15pm
Yeah I did that - it was so I ran a new wire from the dash down - so now it does shut off if it’s disconnected
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 8:25pm
Sounds like green board in dash is bad.    MACK
