7060 dash warning light axces
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 dash warning light axces
    Posted: 11 Oct 2026 at 3:59pm
How do you go about getting to the warning light cluster? I have one that doesn't light up.
68 D21 81 7060
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 6:37pm
Take both engine side hoods off. The small panel, behind the center hood,comes off next. It has a spring hook on each side holding it on. There's an even smaller orange panel that's held with two 3/8ths bolts that needs to come off. It is actually in the cab and directly over the center of the dash. The bolts are accessible on the outside of the cab and are right in front of the windshield. That panel has to be moved forward and taken out front ward. If there's insulation, remove it. Unplug the wiring harness from the circuit board and then remove the 4 screws holding the circuit board to the plastic dash panel. That takes a 1/4 inch nut driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 1:34am
I can see the two bottom screws that holds the circuit board to the dash from outside the cab with the spring held on panel off but the top two screws that hold the cluster cant be seen. I will look at removing the other top panel.
Thank you.
Edited by whatscooking - 12 Oct 2026 at 1:46am
68 D21 81 7060
