7060 cowling sealing
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 cowling sealing
    Posted: 03 Sep 2026 at 4:20pm
Went looking and found what foam was in there was a crumbling mess, nothing stopping the heat. It needs a firewall. Going to remove the bypass filter and make a barrier, going to put of some of that peel and stick sound and heat materal behind that to divert the fan blowing the heat. Its like 102 heat index here today.
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 4:48pm
some of that stuff is just FOAM and is pourous and will leak dirt / air thru it... Some of the stuff is more like caulking and no air pockets thru it......... that might be better ?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 5:43pm
Dynamat will do the job. I dont think it will ever break down
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2026 at 5:47pm
Butler Sound Deadening 80 ml, seems to be respected.
Believe i can stick it on top and fold it down behind the bypass filter bracket and curve back to the floor to block and still keep air moving down and below the cab.
Edited by whatscooking - 03 Sep 2026 at 6:14pm
68 D21 81 7060
