7030 Block Heater
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Topic: 7030 Block Heater
    Posted: 05 Oct 2026 at 4:24am
I decided to put a block heater in my 7030 in case it is needed this winter. It has had a combine engine put in it so it doesn't have one now. I don't know a lot of history on the tractor so I plan to change out the coolant at the same time. The question I thought of is what are the chances of the plug coming out clean after 50 years? And then is there a good way to repair the threads in the aluminum casting? Thanks in advance.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2026 at 7:28am
If it was mine, I'd have the engine fully warmed up to operating temp and carefully use a 1/2" impact wrench to get it to move and know it is loose. Have your hand on the socket to control what's happening to keep it from completely coming unthreaded !!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 9:31am
Heat around plug to grow the AL ?
8070nc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 11:08am
If that elbow is aluminum and you put any appreciable heat there the aluminum is so soft it will take the threads out with very little force. Id do what Doc said and with a impact wrench bump on it maybe back and forth until it moves after it does spray it with penetrant. Patience is your friend. You probably wont have any. Good luck
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 11:09am
Trouble
1984 80780
1957 D14
616 tractor
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 11:31am
Thank you for the advice, I had planned to work on it this weekend but the heater won't get here until next week. Everything I work on at work that is aluminum recommends letting it cool to room temperature before trying to remove anything. I hope it comes out clean and without too much of a fight.
Ted
55allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2026 at 11:55am
My local blacksmith will heat it and cool it several times before even trying to remove it.
He’d remove it at room temperature.
On manifolds I will spray penetrating oil on it several months before it needs to be removed or when we get some new to us.
That way it gets lots of heat and cooling.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 8:09pm
I followed the recommendation of DrAllis and got the plug out clean. I expected that after a revolution or two I would be able to use the long handled ratchet but I ended up using the impact until it started to leak. I used Permatex paste thread sealant on the heater just in case the threads weren't all there and now I have a block heater in my 7030. Thank you again for the advice.
Ted
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2026 at 10:36am
I’ve changed a few block heaters, never had an issue just unscrewing them from the aluminum but I think getting it to temp is a good idea
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2026 at 2:17pm
I looked at my 7045 today. It doesn't have a block heater either, but I don't have plans to use it this winter. I did order two heaters when I ordered one for the 7030 in case the one in the 7045 was bad. Both tractors are new to me this year, so I was planning to change out the coolant anyway, and I'm putting shut off valves on the heater hoses while it is drained. I think the 7045 is going to get new radiator hoses too.
Ted
