7030 Block Heater |
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 376 |
Topic: 7030 Block HeaterPosted: 05 Oct 2026 at 4:24am |
I decided to put a block heater in my 7030 in case it is needed this winter. It has had a combine engine put in it so it doesn't have one now. I don't know a lot of history on the tractor so I plan to change out the coolant at the same time. The question I thought of is what are the chances of the plug coming out clean after 50 years? And then is there a good way to repair the threads in the aluminum casting? Thanks in advance.
![]() Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Thanks(1)
Posted: 05 Oct 2026 at 7:28am |
If it was mine, I'd have the engine fully warmed up to operating temp and carefully use a 1/2" impact wrench to get it to move and know it is loose. Have your hand on the socket to control what's happening to keep it from completely coming unthreaded !!!
