7020 Pulling Tractor
Barnyardpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 10:24pm
I have the power director, would it just be a matter of finding a flywheel from a tractor and changing it?
7020 Farm Stock puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 11:23pm
Yes. I think you'll also need the engine backplate from a 7000-8000 series tractor too, as the combine backplate isn't correct (I think).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barnyardpuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 9:58am
I’m assuming it won’t, but would any of that interchange from the 301?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 9:59am
I think N5/N6 Combine engines use the same rear plate as a D21/210/220. So a 7000/8000 series tractor 426 rear plate will be needed, should be lots of them around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 7:41pm
If it were me- this West Allis metal in things are showing its age- maybe put a steel flywheel and clutch package in it, just an opinion
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 8:03pm
The flywheel isn't used as the clutch. The Power Director inside is a wet clutch that doesn't explode.
