7020 clutch pedal
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Topic: 7020 clutch pedal
    Posted: 12 Oct 2026 at 8:41pm
My 7020 clutch pedal yesterday went to the floor and no return.  Worked great on Saturday baling the last of our hay, backed it in the shed shut it off.  After church we went out to clean up the baler and put it away for the year.  Got into start her up, pushed the pedal and pushed easy and fast.  Did start as the safety switch must be activated, but didn’t move,  put my foot under the pedal and lifted it up.  Got it to move as long as I pulled up the pedal.  So my question is what happened and how can I fix it!  Thanks Kurt
WD D17D 170 190xt 190xtIII 200 7020
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 10:03pm
Quick fix if you need the tractor is a tarp strap wrapped around the clutch pedal and up to the steering column. The real fix is to replace the broken clutch pedal spring inside the instrument panel. This is a Power Shift tractor, right ???
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 10:08pm
It has to be a power shift. And yes, broken return spring on the pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 6:22pm
Yes it’s a power shift.  Got the dash panel off today, found the broken spring in there.  Now where exactly does it get hooked to.  And do I need to take more panels off to replace it?  Any one got a replacement spring for sale?  Agco part books don’t even show much Allis anymore!  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2026 at 6:39pm
As far as I know any AGCO dealer can get it for you.
