7016 battery |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9240 |
Topic: 7016 batteryPosted: 21 Apr 2024 at 10:38pm |
I have a 7016 Simplicity w/16hp Briggs. The original battery was an odd size that Ford used and is rather expensive. Could never find it as a sealed version so they always ooze out the caps,make a mess and don't last over 2 yrs. What's the answer? I have a 25hp Kohler in a zero that uses the little square 'lawnmower" battery and it's fine but the 7016 has the starter/generator system so I don't know if a "lawnmower'' battery would do. Any ideas?
I have a B1 with a 10hp Briggs and it uses the starter/generator and little battery and does great. Edited by SteveM C/IL - 21 Apr 2024 at 10:40pm |
Leadoff
Posted: 22 Apr 2024 at 11:01am |
Steve M C/IL
I have an Allis Chalmers 716H, with 51R 12 volt battery, CA 615 amps / CCA 500 amps. The tractor is the Allis Chalmers twin to your Simplicity 7016. It is also one of the few that was shipped from the factory with a 16 HP Briggs and Stratton engine. It does not have the belt driven starter/generator earlier models featured. It is a later model (1978) and has a small 12 volt electric starter, and the battery charging system has an alternator stator assembly mounted inside the flywheel. The battery gets charges up just fine. ![]() |
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
SteveM C/IL
Posted: 22 Apr 2024 at 11:08pm |
I have a second 7016 (now parts) which has the starter and charging system like that. They put a dip stick in the block because of starter. Kinda hard to retro that. Don't remember if block has some extra bosses for the stator that my other one don't have. I do like your battery.
Starter / generator is a 74, separate starter is a 79 Edited by SteveM C/IL - 22 Apr 2024 at 11:11pm |
