7010 pto reassembly
190 driver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190 driver Quote  Post ReplyReply Direct Link To This Post Topic: 7010 pto reassembly
    Posted: 13 Feb 2020 at 5:48pm
I'm putting new seals in the two speed pto on my 7010.  When putting the bearing on the front of the 1000 rpm solid shaft, is it best to heat the bearing to install or tap the shaft into it?  I can't see where pounding the shaft into the bearing would be good for either the bearing or the race.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2020 at 7:44pm
I have always driven the shaft into bearing. Don't fit all that tight.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190 driver Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 5:21pm
Thanks for the advice.  It went on better than anticipated.  How tight does the big nut on the solid shaft go?  Just snug or snug and a little more?  Snug and back off?  The I&T isn't real good on things like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 5:33pm
Just tight enough that there isn't any looseness in the stack of parts. You get it too tight and it will fry that flat needle bearing. On the same note, any looseness and your seals will leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190 driver Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 6:09pm
Thanks for all your help.  That's kind of what I figured.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 9:06pm
I like to tighten the but tight to make sure all the slack is out, then loosen to where it turns free.          MACK
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2020 at 9:07pm
NUT not but.      MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2020 at 7:04am
There's a joke in there that I'm leaving alone Big smile
Wink
I am a Russian Bot
