7000 black belly hydraulics
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: 7000 black belly hydraulics
    Posted: 50 minutes ago at 2:11pm
I recently started having issues with my black belly 7000 I use to bush hog with. The first symptom was when I first would start using the bush hog sometimes the pto would disengage when I would shift the powershift. This normally quit after I had worked it for a while. The last time I used it, that was much worse and I wasnt able to raise or lower the wings on the mower. I have plenty of the correct fluid in it (both compartments). It still steers fine. Where do I need to start? Its been a while, but I have adjusted the stand by pressure on the 7060 type tractors but this isn't the same system and im a little fuzzy on the routine anyway. Thanks in advance.
