6080 starting
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: 6080 starting
    Posted: 17 Sep 2026 at 7:46am
So back in the middle of July I did some maintenance on the old girl, including new batteries and cables. I mention this because the engine now spins so much faster it’s not funny. Also starts much faster/better. I think the cables were the big thing, corrosion was pretty bad. The other night it got down in the mid 50’s, curious, lets see if it will start? Spun a little bit but lit pretty quick. Before, it would have never started without being plugged in.
Moral of this story; Faster cranking speed=good! If you have a hard starter, look into the cables. They might just be the problem.
Just remembered, need to get an oil filter so I can finish the maintenance up on this one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 3:06pm
Yup- so true, had a newer Harbor Freight winch - 2 years old that slowed down bad- cut the battery cables cover was green and bad - put new ones on - worked perfect- a week ago my 5020 done the same - new positive cable and good to go!
Ricky38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky38 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2026 at 12:00pm
Crusty cables cause so many fake fuel problems. Glad it's spinning faster. Get that filter!
