6080 joystick
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: 6080 joystick
    Posted: 01 Aug 2026 at 1:44pm
I need to replace the joystick on my 6080, it is plumbed into the tractor hydraulics. I have a second joystick from a different loader that I never used or any idea what the loader came off of, it has lines that run from joystick to the remote outlets.  I want to mount the second joystick, remove the lines going to the remotes and plump it into the tractor hydraulics. Are all joysticks compatible? Anything I need to know before I think about changing them and maybe damaging the tractor hydraulics?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 8:11pm
As long as its open center i dont see anything it could hurt but id make sure it is open center. If its closed center as soon as youbstart the engine all oil would have to go through the relief valve. Of course it cant work like that. Thats the only advice i can give you at this point
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 8:31pm
Thanks, that is what I was wondering about. how do know the difference between open and closed valves?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 9:57am
I could figure it out if i had it. Ti tell you how to fugure it out is something else. The quickest way probably is to take a air blower and a rag and hold it in the inlet port. Rag is to seal it up the best you can. If air passes through the valve with little resistance it open center. If it builds pressure and forces the blower out in your hand its closed
1984 80780
1957 D14
616 tractor
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 6:08am
According to tractor data dot com it’s open center.   Right or wrong I’ve been told older are open.   If it was mine I’d take the seat out, the tin under the seat out, and finally remove the couple bolts that mount the valve stack down.  Then I’d find the line going into the stack and the line coming out and put a tee in each.
But that’s just me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2026 at 6:03pm
Finally got time to check the joystick on the unused loader I have, I did as 8070nc  suggested and air will not blow through it, so I guess it is a closed center joystick. As for the joystick that is mounted on the 6080 now, it is plumbed into the hydraulic system under the floor. the joystick on the tractor leaks and I was hoping i could replace it with the extra one. Oh well, thaanks!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2026 at 3:51pm
how does the joystick leak ?   does the spool valves operate with pilot lines ?
