301
Bobo Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Topic: 301
    Posted: 02 Apr 2017 at 9:41am
I have a stock 301D in a 190xt. Would like to bump up HP.
I am reading that connecting rods may be a weak point. Could anyone give me input on what HP and boost they will hold up to?
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 9:43am
Always heard that they can't take much more than 45 lbs of boost, timing affects this too, don't go over 36 degrees,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 9:47am
Oh ok. Good to know. Any idea on how much HP before they scatter or is that not a concern?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 10:19am
If you stick with your turned up Roosamaster and a little turbo upgrade you should be fine, I pulled the crap out of a 200 turned up like this for a few years and no problem,, could pull in 5th in the 9000 class, mostly 4th tho, never had power issues
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 7:49pm
A friend of mine runs a 190 with stock bottom out of a gleaner with an a pump more then 60lbs 4200 rpm for last 6 years
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 8:59pm
Always better sate then sorry
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 8:12am
Sorry = very expensive
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 5:43pm
2 cents: get hardened rods and wile you have the pistons out get the sleeves cut for fire rings and sleep easy. maybe go as far as cut pistons and copper gaskets
