301 gleaner motor
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Topic: 301 gleaner motor
    Posted: 08 Jun 2026 at 7:19am
lets try this again, what is needed to put a 301 gleaner engine in a 7045 chassis?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2026 at 7:49am
To start with, you'd like to have a 7010-20 engine backplate and a flywheel to match which transmission is in the 7045 chassis. Front motor mounts can be fabbed. Air conditioner compressor brackets are all different and hoses might not reach. You might be able to mount the compressor in a similar location front left side by making your own brackets. Coolant hoses will be easy I think. Exhaust pipe (not a muffler) elbow can be fabbed or maybe a straight pipe will hit the hood hole anyway. Throttle/governor controls will have to be fabbed up unless you can find a 190/XT gas engine to steal from.
This page was generated in 0.039 seconds.
