301 Diesel cam upgrade?
PA185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Topic: 301 Diesel cam upgrade?
    Posted: 28 Jan 2021 at 3:39am
Anything out there for a 301 Diesel cam upgrade?
Steadying building my 185 for the local farmstock classes this winter.
It’s a non turbo (local rules do not permit a turbo so I cannot add one)
Specifically looking into info for a cam and roller rockers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 4:32am
Been interested in this too- I think they re- degree the lobes on stock ones wish I had more info
injpumpEd View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 8:02am
Vogel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2021 at 12:06pm
I guess I'd expect no gain at all until you increase the fuel delivery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 3:31am
That’s taken care of. Just got my pump and injectors from Ed, plus designed my own cold air intake set up. Next upgrade would be a cam or rockers.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2021 at 10:36pm
Roller rockers are a waste of money unless a lot of RPMs.           MACK
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 9:02am
   Longer ratio rollers might be worth it, maybe wouldnt need cam?
  Are the 426 rockers the same as 301?
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 10:23am
I just picked up a 3000rpm cam from a guy in PA, was a Vogel cam
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 7:58pm
Vogal seems to have one profile for a 301 gas or diesel doesn’t seem to matter that’s a 375f 212 and works well no one ever seem to have a complaint or probably set on a dyno and compare that cam to any other. They use decent lift and less duration. But if you really want a cam that is just for your tractor I would call Eric at no limits and get one reground. but before you do that get your head flowed and have flow numbers and as much information as possible you can give him the better and will grind what you need. With that said you can have more duration and use rockers to make up the difference with lost lift to achieve what you need. For a turbo diesel or high rpm gas a cam is way more beneficial then a N/A diesel
This page was generated in 0.088 seconds.
